Dying psu or too much wattage? Be Quiet Power Zone 750W
Tír na nÓg
Hi lads,
I have this PSU for 2/3 years, serves me pretty well, but I am wondering if it's not dying.
http://www.hitechlegion.com/power-s...t-power-zone-750w-psu-review?showall=&start=3
When running Real Bench, with the GPU and CPU overclocked (see sig), the PC sometimes reboot. Not always, once in a while.
I believe RealBench runs both CPU and [email protected] load at some point (I happened to have the GPU crashing with some test...).
Quick calculation and some "googling" and I end up with a total TDP for CPU+GPU around 220W+380w. That's 600W. Add a few fans, pump, DDR and MoBo.
But still, with 12V*62A, I should have some room. Unless the CPU and/or GPU use(s) more power than I think.
Or it's dying, lol!
caddi daddi
Godzilla to ant hills
a 750w psu should run about any single card rig anyway you clock it, try cleaning out the video drivers and reinstall.
Tír na nÓg
Tír na nÓg
Just did: DDU and the whole shebang, 347.52 and 368.39. Same thing.
Pfff... Should have taken this Corsair ax1200i and 780ti combo for 350euros... Now the card is gone...
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
That system isn't breaking 550W like that while running furmark and p95 at the same time bud. Unless the psu is going bad (test with another one) I'd look elsewhere.
Tír na nÓg
Tír na nÓg
^Yep, that is what I think as well, was counting on 600W max, with fans, pump... Have a spare Cx600. Not the best, but it will give me the answer.
Thanks guys.
EarthDog
Buckeyes!
Did you BIOS mod the 780Ti? You may not be hitting that much if you didn't raise the power limit. ;)
Tír na nÓg
Tír na nÓg
Yes, I modded the original BIOS to 100%/300W - 150%/450W.
@C-D: Yes, will do that on Friday and let you know the outcome, after having changed the front left suspension arm of my GF 2001 1.2l Fiat Punto, if I survive it, lol!
