- Aug 5, 2002
- Brisbane, Australia
Swapped out my Pentium D 3.46Ghz 955XE Extreme Edition for my Intel Core 2 Duo E6600 B1 Step 5 cpu to see how well the Scythe Infinity cools compared to other air and water cooling I tried.
Cooling used:
A few notes:
System:
How does Scythe Infinity compare to other cpu cooling solutions I have used on the Intel D975XBX Bad Axe platform ?
Dual stressprime orthos small FFTs load with Coretemp temps reported for:
Room temp: ~20-22C
Cooling used: stock Pentium D 2.8Ghz 920D heatsink + Sunon 80x25mm 49cfm fan
Bios idle: 52-56C
Windows idle: 40-43C
Windows load: 74-75C
Rise above ambient delta = 53-55C
Rise above windows idle delta = 32-35C
Room temp: ~21-24C
Cooling used: Thermaltake Big Typhoon + Thermaltake 120x25mm 81cfm fan
Bios idle: 38-40C
Windows idle: 32-33C
Windows load: 47-48C
Rise above ambient delta = 24-27C
Rise above windows idle delta = 13-16C
Room temp: ~20-22C
Cooling used: Corsair Hydrocool 200EX + Thermaltake Big Typhoon LGA775 mounting gear
Bios idle: 31-32C
Windows idle: 24-28C
Windows load: 36-40C
Rise above ambient delta = 18-20C
Rise above windows idle delta = 12-16C
Room temp: ~26-28C
Cooling used: Swiftech G4 Storm Water + Thermochill 120.3/MCP650 Pump
Bios idle: 32-36C
Windows idle: 31-33C
Windows load: 37-44C
Rise above ambient delta = 16-18C
Rise above windows idle delta = 11-13C
Room temp: ~27-29C
Cooling used: Scythe Infinity + 2x Thermaltake 120x25mm 81cfm push-pull
Bios idle: 40-43C
Windows idle: 35-36C
Windows load: 50-51C
Rise above ambient delta = 22-24C
Rise above windows idle delta = 15-16C
Idle
Dual Stressprime Orthos small FFTs load
Cooling used:
- stock Pentium D 2.8Ghz 920D heatsink + Sunon 80x25mm 49cfm fan
- Thermaltake Big Typhoon + Thermaltake 120x25mm 81cfm fan
- Scythe Infinity + 2x Thermaltake 120x25mm 81cfm push-pull
- Corsair Hydrocool 200EX + Thermaltake Big Typhoon LGA775 mounting gear
- Swiftech G4 Storm Water + Thermochill 120.3/MCP650 Pump
A few notes:
- This is first time i have used my E6600 B1 cpu since i re-lapped the IHS, first lap was half *** job with alot of scratches but this time it's alot smoother and shiny.
- Please keep in mind other results were done at different room ambient temps compared to current Scythe Infinity tests.
- I'm using a different power supply, before it was either 700W OCZ GameXStream or 1KW PCP&C SLI psu. Now, I am using the new 850W OCZ GameXStream which has 4x +12v rails rated at 20 amps each - of which 2x +12v rails are for independent PCI-E connector power.
- I've figured out how to use Intel D975XBX Bad Axe's Intel Desktop Utilities (IDU) application which reports temps, vcore etc. It seems if at any time within a windows session you load cpuz, clockgen etc, you will cause IDU to freeze or hang. The only way for IDU to work properly is if within the windows session you don't load cpuz or clockgen if you intend to run IDU.
- Due to IDU issue and fact D975XBX Bad Axe board from bios only allows max 400fsb, it means for tests at >400fsb that require increasing fsb from clockgen, I will have to only use coretemp app to show temps and not use IDU.
System:
- Intel Core 2 Duo E6600 QPGE B1 Step 5 ES
- Intel D975XBX Bad Axe rev304 1334 bios
- 128MB Gainward FX5200 PCI card
- 2x1GB Gskill PC6400PHU2 HZ Micron D9GMH 0629 batch
- 3x 320GB Seagate 7200.10 SATAII hdds
- Pioneer DVD-RW Burner
- 1.44MB FDD
- 850W OCZ GameXStream (quad +12v rails @20amp each)
E6600 stock @2400Mhz at 1.275v (bios = 1.254v)
Room temp: ~20-22C
Bios idle: 52-56C
Room temp: ~21-24C
Bios idle: 38-40C
Room temp: ~20-22C
Bios idle: 31-32C
Room temp: ~26-28C
Bios idle: 32-36C
Room temp: ~27-29C
Bios idle: 40-43C
Idle
