Good news and bad news. The good news is that I reached my minimum goal of hitting 3.0ghz stable. I taded my original 2.0 NW plus $25 for the new C1 stepping from someone who pulled 6 chips out of new Dells. So for $25 net, I am happy. The bad news is that it took 1.75 volts to get there stable. Stable for me is Prime 95 forever. So far so good, 24 hours of Prime95 is good enough for me but it has not been 24 hours, but you kind of know when it will do it or not. The seller had 6 chips and a few did 3.32 at default voltage, so he says. He mixed the 6 up and shipped them out. I assume the lucky folks got the 3.32's. This chip will not go that high with air. It took a lot of work to get to 3.0ghz. All in all - a nice bump in OC potential from the original 2.0A, where 2.5 was a lot of work with air. The details:
SL6GQ
Temp 42 min 62 under Prime95 Torture Test
Volts 1.78 High, 1.72 Average per MBM
AVC Sunflower
AS3
RAM at 3X 450
I have a CPIUD screenshot if someone want to host it.
I will try for higher only if it can go higher with the same voltage. I want to let it run at 3.0 for a while. You never know.....I'll keep you posted. Any comments on the voltage? Dangerously high?
SL6GQ
AVC Sunflower
AS3
RAM at 3X 450
