Easiest Way To Improve FPS
SC4P3G04T
I just wanted to know what the easiest way to improve fps is b/c im always looking for a more enjoyable game experience. Im actually talking about like ramsinks and vga silencers and stuff what will give me more fps w/o tweaks.
THANKS
Unreal89
I dont think its possible to increase FPS by just slapping on a VGA silencer or better cooling. You will need to overclock. You can try the omega drivers, but they also dont help much unless you tweak and overclock.
S
SC4P3G04T
alright thanks I was confused. but the more cooling the better o/c i can get I just dont like tweaking b/c somethin thats supposed to be there isnt anymore. but I have 60 in call of duty. Just looking for more. Thanks for yalls help. I will try out the omega drivers. what exactly are they. just a different driver instead of the catalyst ones? educate me! :p
Docta_Z
Canada
The omega drivers are optimized versions of the catalyst drivers.... modified to change some of your system's video options for the best performance in games, and other 3d applications.
The latest can be found at www.omegadrivers.net
Keep in mind, you want to completely clean your old drivers off your computer before installing new ones - using a program called "Driver Cleaner" and following the instructions it gives you on how to properly remove all old drivers. If you don't remove your old drivers you could create conflicts and further slow down your fps in video games.
CircuitBreaker8
Disabled
Silver Spring, MD
Docta_Z said:
Please try to use proper english if you have anymore questions.
WTF was that? :rolleyes:
stratcatprowlin
Senior Member
MG,Brazil
Yeah, what was wrong with that English?
A little puctuation absence never bothered me.Thats how we write on forums.
Its not a High school essay.
stratcatprowlin
Senior Member
MG,Brazil
CircuitBreaker8 said:
overclocking is overrated...
lol,I think it is too but isnt it funny that we're on an overclocking site?
I like it here because I learn about the hardware and software but I hardly ever overclock anymore.
Drec
yeah and how do you know english is his native language...thats very rude.
YellowDart
Mesa, AZ
The best way to increase your fps eh???
Well, imo, the best way to do that is to shell out $500 for an x800XT. :p
If you can't afford to do that (like most of us), then I suggest grabbing the latest Omega drivers, slap a VGA Silencer and some ramsinks on that card and OC the snot out of it. :D:D:D
CircuitBreaker8
Disabled
Silver Spring, MD
So you can gain a whole 5fps! :beer:
Silver
Senior Citizen (aka old fart)
Dallas, Georgia
To state the truth! OCing your videocard doesnt do anything! Want some compare links?
No, I think I would rather see some test results on your processor, etc. :rolleyes:
Spongebob3000
OC can help i have an old 9200 in an XP2200+ PC with 256MB DDR Ram and putting an old Amd HS on the 9200 and OC'ing 50Mhz to the core and 18Mhz to the ram(ya i no it has crappy ram) dose make Call of duty Run alot smoother on it then at stock speeds.
theELVISCERATOR
THANKS
easiest way is to drop your resolution and graphic settings.
