EasyTune 4 - unable to change voltage
shale00
Hi
Any of you familiar with the EasyTune 4 utility will know that the settings which allow you to change Vcore voltage, AGP voltage and divider are 'behind' a pair of metal 'shutters' on the interface, well, on my pc they just dont open, so i can only change FSB and not voltage etc.
Also there does not seem to be a way to change Vcore voltage in the BIOS.
Thanks
GA-60xt(-A)
Celly 1400
384 MB RAM
Samsung 20g HDD (7200RPM)
Creative Ge3 2Ti
nixie
Southampton, ENGLAND
I see that its the 60XT version of the board you have. Well unfortunately on this board voltage adjust is not possible, only the 60XET (-c) have this feature. As you have discovere the only change you can make on that board is FSB.
If you do want a little more voltage you will have to to the vid pin wire wrap trick (see stickies in this forum).
