Noise from update coolers is very hasitating feature for around people and for myself.
I have, for example, ElanVital FC-6 for Atlon Xp 1600.
It makes 41 degrees with 4300 rotation speed.
And not changing at any work,- only for 4 degrees.
And this is makes unneeded noise.
So I need to find the bettter as possible solution for noise reduction.
There is three sound ways from cooler-
1- By air within computer.
2- By mechanical propogation through the MB and case.
3- case as resonator effects.
It is also need to define what is proportions betewen them, to eliminate most bad step by step.
First way may be good resolved using case wraping within them by porolon material, or plastic cover with air cavities, got from monitor buying pack.
May it be three layered paper, second -making air field between two others.
So it need to advice which of them is most effective, and worth to use this double to increase effect, or there already is need to take into attention two other ways of noise distribution firs?
(Noise is hasitating, so if people saying that your eye worth money, then you health suffering from sound may be too.)
the second part of first question is- worth to make some attached to cooler device to eliminte noise already where it appears, making protection layered?
The more dificalt qustions is how to eliminate two others ways of noise distribution.
It may be some noise compensating (from advanced things) or just absorbing as in first way, but here is also need to choose effective solution due to mechanical part must be not fly on air(desired, but low probable, to my suffer) but
some firmly connected.
And making this connection is not sound condactive is the important qustion.
Making case not resonant - showing how works your HD and cooler moe than they self does, the also very interest and not very simple.
Some solution there is at cars. May be some analogous ideas?
May someone propose some solutions or evaluations for this noise eliminating questions ? Thanks
