I would like to build a water cooling system, where water flows down due to its own weight. A reservoir is in the cupboard above the computer, and another reservoir is below the computer. Water is pumped back up from lower to higher reservoir.
The flow rate is high, about 4 liters per min, when the water reservoir is 60 cm higher than the output pipe. A 8 liter bucket would empty in two minutes. The pumping must be really effective.
The good thing about the reservoirs is that a single pump isn't needed. If an efficient pump is expensive, two small pumps can be used. But which is cheaper? Getting one big or many small?
Then there is also the problem with the flow rates. If the pumping is slower than the cooling flow, the upper reservoir will empty, cooling will be ineffective and bang!
The opposite isn't that bad, but the constant "slurping"...
