eheim owners...
awol
i just bought a used eheim 1250 and it works great... but it didn't come with the attachment to be used as an outside pump.... so can someone tell me what the size of the inlet fitting is? and where can i get one? maybe home depot?
i want to run 3/8" hose from it...
thanks for any info...
I use the same and I believe the inlet is a 3/4" to 3/8" adapter. You can get a plastic/nylon one at any hardware store for under a buck. Get the screw in kind. But what you really want to do is get a 3/4" to 1/2" screw on. It will stretch the hell outta the hose but you will get as large a hole as is the 3/8" tubing. Trust me. The outlet is 1/2" too.
awol (Jun 21, 2001 08:32 p.m.):
is it quiet?
AmIdYfReAk (Jun 21, 2001 10:35 p.m.):
is it quiet?
extremely quiet!! i can barely hear it... and it works great! 300+ gph...
i'm testing my water setup for leaks before i stick it in, and so far so good. homemade block and all...
nice..... thats the one that im getting then.. :)
im goin to do twhat toms hardware did.... but with that pump instead....
Tacoman667 (Jun 21, 2001 09:16 p.m.):
thanks for the info... greatly appreciated. i will go look for an adapter tomorrow.
