EK-KIT P280 Water Cooling loop help
H2mike
I decided to go with a custom water loop EK-KIT P280 for my Corsair Obsidian 750D case and Asus X99-A motherboard and I7-6850 CPU.
This is going to be a very expensive build for me and I was wondering with a EK-KIT P280 loop, how do you know if your pump stops working while your CPU is under heavy load video editing?
I know, your CPU burns up!
Is their any alarms or systems I should have in place to prevent this or is this so rare that I shouldn't worry?
Is their any inline water temp or flow meters I should use to know my pump is starting to fail?
Thanks
