- Jun 27, 2012
Looking for opinions on the EK predator 360mm edition. I really like the design that has the pump and small reservoir attached to the radiator. This drastically reduces the amount of room needed for tubing. In the review from guru3d, they tested a water cooled r9 nano and 4790k just using the 360mm radiator and results were very very good.
All this said, will the pump in this kit be able to push through 2 blocks(1 cpu, 1gpu) as well as a second 240mm radiator?
