- Oct 19, 2008
- England, United Kingdom
Hi Guys just wanted to ask a simple question:
Scenario ::
In about 2 months or so (mid to end of Jan) i'm looking at getting my first i7 setup.
It is likely that i will get the EVGA X58 SLI LE with the Acetal EK full board block.
I want this watercooling to be asthetically pleasing as possible.
Therfore I have come to the conclusion that the EK Supreme LT will look the best since it matches the MB Blocks ::
The i7 CPU block roundup over at skinee labs concluded that the block performs 4 degrees worse than the Swiftech XT...
Is this a big deal condsidering the EK Supreme LT costs around half the price?
WIll it perform efficiently enough for an i7 920 @ 4GHz?
(I will be using a XSPC RX360, TC PA120.3 or the new EK 360 rad depending on if iI can get one)
I like things to look nice... the Blocks will be equipped with Bitspower Shiny Black Compression fittings and Feser Red 3/8"ID 1/2"OD tubing.
Scenario ::
