Hello Overclockers Community,
I've just noticed that my reservoir on my EKWB pump has started to turn a white color around the inside of the glass inside the reservoir. I’m worried that something may be wrong with it.
I’ve moved my case to a different room recently, but I don’t think this would affect the reservoir.
My CPU runs at 37 C on idle and runs around 65 - 70 C on full load, maybe the heat is causing it to lose its color? I don’t think this is the issue because when I look inside the reservoir, the liquid is still colored purple, or so I believe because the color inside the tubing is still purple.
The loop I have cools my CPU which runs at 37C - 70C and my GPU which runs at 32C - 45C depending on the load.
EKWB Components:
Liquid – EK-Cryofuel Solid (Electric Purple)
Tubing – EK-HD Acrylic Tube
Radiator – EK-CoolStream SE 360 (Slim Triple)
Pump – EK-XRES 140 Revo D5 RGB PWM (included. sl. Pump)
CPU – EK-Supremacy EVO – Acetal+Nickel (Water Block)
The liquid is still purple because it shows it in the tubing.
I'm using clear tubing.
I don't think it's foam because foam would be sitting at there very top and there doesn't seem to be any thing at the top. (Just around the sides)
EKWB Components:
![IMG_6273[4979].jpg IMG_6273[4979].jpg](https://www.overclockers.com/forums/data/attachments/204/204846-8aac6398f74eb9b7079f10346f922986.jpg)
