Enable onboard video with graphics card?
N8N8N8
PA
Hello
I have 3 monitors and have 2 running on my video card. How can I enable onboard video to run my 3rd monitor on my 6700k onboard video or is this not possible to have a onbaord video and video card both enabled.
My MOBO is the Krait z170a 3x
Thanks
Nate
jaymz9350
You should be able to use both, I do on my 4790k. Make sure the iGPU is enabled in the BIOS and has the proper driver installed, that's all I had to do to get mine up and running.
N8N8N8
N8N8N8
PA
Where do I download the drivers from or how do I tell what one I need?
N8N8N8
N8N8N8
PA
GOT IT :)
thanks so much both of you.
First I got an error but needed to enable the it in the bios before installing the software :bang head
