energy saving problems?
danomite664
Iowa
Ok, i am using win98 SE and I used to have the energy saving features enabled (both the monitor shutting off and hard drive turning off) but it was causing problems (i.e. computer freezing and me having to restart every time), so i just turned off the energy saving stuff. Should I worry about it causing any problems in the long run by not using this stuff?
jrbob
Billings MT
Not at all, I have read someplace that it is harder on the drives having them start and stop all the time than to just let them run.
Audioaficionado
Sparkomatic Moderator
I have it shut down the monitor in one hour as that will save over half the energy used by the computer. The HD shouldn't be hurt shutting down but if you have trouble waking up your system check and see if you also enabled the standby mode. I always had trouble with that too but not the monitor or HD.
