Does anyone know if a Thermaltake Big Typhoon or Scythe Ninja will fit into the airtunnel of an Enermax CS-718 (blue viper) case?
anyone out there who owns this case and tested the 2 heatsinks?
what about with the wind tunnel removed?
thanks
tell me one heatsink that is better than TT Big Typhoon or Scythe Ninja... NONE.
Thermalright has very very good heatsinks better the other to are juste better
thanks
It would be a very very tight fit at best. I think it would have alot to do with what motherboard you used... but I would not expect it to fit. You culd always make your own duct out of acyrlic.
