Abit IP35-Pro, Intel Q6600, 2 WD 6400AAKS hard drives in RAID-O, 2x2 G.Skill F2 8000, MSI 9600GT, Corsair HX520-X
Be using it to capture and edit video using Premiere...Will taking a slice of the Matrix give me any real world performance increase ???
For video editing, you want a high sustained transfer rate (STR), lower access times are less important.
So the
access time benefit you get by short-stroking your drives (either by the partitioning method that tusken prefers or by creating a smaller RAID 0 "slice" in a Matrix array) isn't going to help your task.
However, there may still be a benefit for your work - the first array you create on a Matrix controller is on the outside of the disks' platters, which is the fastest part from an STR point of view. So if you could configure your system so that you had this "slice" be your work area and you didn't fill this slice up with other programs, OS etc, you would always be sure of getting the best possible STR from your drives. If you just put everything on one volume then as the volume fills up you are using the slower inner parts of the disk (which are often less than 50% of the STR of the outer).
I do some video editing and I use a 3-disk RAID 0 slice as my workspace, giving me about 300MB/sec throughput. It works very well for what I need.
