Ok, so thinking of this case - http://www.newegg.com/Product/Produ...54003&cm_re=enthoo_pro-_-11-854-003-_-Product
Have these fans - http://www.thermalfx.com/merchant2/...T&Product_Code=109R1212H101&Category_Code=120
CPU Cooler - Noctua D15 with both fans (facing / blowing towards rear exhaust)
So, here is my question. The arrows take care of all possible fan locations for my given setup. I plan on replacing the two stock fans with mine. I like my fans ~ Anyway, I was going to put two on the top as exhaust, two on the front as intakes, and one on the rear as exhaust. I felt that the one on the bottom (as either I or E) would disrupt airflow and I was not going to put one in the rear most top slot, as I figured that too would disrupt somewhat the airflow for the CPU / exhaust. I figured in this configuration I would maximize airflow / cooling.
My question is, THEORETICALLY, does this setup sound good? Right? What are the problems / problematic assumptions? I don't have the case yet and want to order fans, extension wires, etc. so I can get going on day one of its arrival.
Thank you!
Thank you!
