Ishakir said:Hello,
I have not changed it from 100 fsb default to 133. Would I see any difference if I did change the fsb on JCK1 to 133? Or is the BIOS able to override it and set it at 133.
What I'm trying to say is, is it worth the trouble to disconnect the machine, open up the case, and change the jumper?![]()
Thanks a lot
-Ish-![]()
Originally posted by RangerJoe
it doesnt show up at pc3200 because 1. you are running at pc3200 speeds (400 mhz fsb) and 2. its not REAL pc3200..just overclocked pc2700 chips...thats why
ronin1967 said:JCK1 is one of two jumpers on the EPoX motherboard you have.
JCK1 is located above and to the left of your AGP slot, by default the jumper is set on 1-2(100MHz) you want to move it to 2-3(133MHz). The other jumper is JBAT(a very good one to know). It is located between the IDE and RAID connectors. It resets the CMOS(BIOS). It is normally on 1-2, but when you do go overboard and mess things up you will want to turn off all the power(even unplug), then move it to 2-3, wait a minute, then move it back 1-2, and power up, it resets the BIOS to default settings.
I have heard rumors that at 200MHz FSB a new mutilpier kicks in and the AGP/PCI run at default, even thought they show 40/80 in the BIOS. I have never had the chance to run that high, and have never seen any hard evidence to prove it, although I hope it's true.
ronin1967 said:
***GINGO***
Here is how to remove the splash screen on startup:
1. Enter the BIOS(Del)
2. Select "Advanced Bios Features"
3. Scroll down to the bottom of the list
4. change "Full Screen LOGO Show" from [Enable] to [Disable]
5. F10(save & exit)
ronin1967 said:now what you have to figure out is how to add your own splash screen in...
don't ask me, I have no idea, probably have to program one into the EPROM, of course there is a good chance there are several already hidden on it...
