System Configurations:
-Mainboard: EP45-UD3R
-Processor: C2D E8400
-VGA: Nvidia 9500GT 1GB DDR2
-RAM: 2x2GB Kingston HyperX 1066 Mhz Ram (KHX8500D2/2G)
-CPU Cooler: Asus V60
http://specialtech.co.uk/spshop/files/detail/v-60.jpg
-Power Supply: Asus 550W/500W
First without any overclocking i couldn't get my ram to work at 1066 :S
i took the ram timings from the official website which came out to be 5-5-5-18 with 1.8v , and 5-5-5-15 2.25V but i could never boot with it.
i searched the forum and tried this template ( A ) but still i couldn't boot, nothing comes on screen and then bios reloads the old settings and reboot.
Template A
however i ended up running my system with this config, but still ram is running on bus 800mhz, with a cpu temp of 42-47 Average
1)Please Advice, how can i run my ram on 1066MHZ ?
2)If you have any over clocking advice please mention it, i dont know how far can i go with this system.
Note: I have found this ram table http://i250.photobucket.com/albums/gg264/pyongmu/STRAPSDIVIDERS.jpg?t=1233275713 dont know if it can be useful
Template A
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto or Fast
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................: 3.609
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 401Mhz
PCI Express Frequency (Mhz) .........:Set to 100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< 800
PCI Express Clock Drive.................: <<< 900
CPU Clock Skew (ps)....................: <<<
MCH Clock Skew (ps)...................: <<<
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 2.66D (you could also for easy setup for now use 2.00D or 2.00B so ram would be 900Mhz, and use tighter timings)
Memory Frequency (Mhz) ..............: 1066Mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................15/18
Advanced Timing Control
tRRD...........................................3-4
tWTR..........................................3-6
tWR............................................4-6
tRFC...........................................52-62
tRTP...........................................3-5
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength ............................800/1066/1200 (Test all three last, use 1066 now)
Channel A
Static tRead Value.........................:6/7-10 333/B MCH - 8/9-12 400/D MCH
tRD Phase0 Adjustment...................:<<< Leave for all below as well
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Motherboard Voltage Control
Voltage Type.………... Manual
CPU
CPU Vcore….……….........................:1.25-1.36 (All up to your chip)
CPU Termination…..... 1.200V*.......: <<< 1.2-1.36 (1.2-1.28 likely plenty)
CPU PLL…………………....1.500V*.......: << 1.5
CPU Referen.…………....0.755V*.......: <<< .64% Of Vtt (Termination above) Auto Will set this correctly
CPU Reference2………,,0.800V*.......:<<< .67% Of Vtt (Termination above) Auto Will set this correctly
MCH/ICH
MCH Core…………….....1.100V...........: << 1.2-1.3 (1.22-1.26 likely good)
MCH Reference….…….0.800V...........; <<< Leave
MCH/DRAM Ref.…......0.900V...........: <<< Leave
ICH I/O……………….....1.550V............: <<< 1.5-1.6
ICH Core…………...……1.100V............: <<< 1.1x-1.2
DRAM
DRAM Voltage ……....1.800V............: 2.0-2.1 (2.2V max, not needed likely)
DRAM Termination .…0.900V............: <<< Leave
Channel A Reference 0.900V............: <<< Leave
Channel B Reference 0.900V............: <<< Leave
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled] Enabled if you use Vmware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect ..............[Disabled] *Note* Must be enabled to flash from USB
Code:
Robust Graphics Booster ...............: Turbo
Clock Chip Control
CPU Host Frequency (Mhz) ............: 400Mhz
PCI Express Frequency (Mhz) .........: Auto
Performance Enhance...................: [Extreme]
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 800Mhz
tRAS..........................................18
Channel A
Static tRead Value.........................:9
tRD Phase0 Adjustment...................:Auto
Same for Channel B
CPU
CPU Vcore….……….........................:1.21250V
CPU Termination…..... 1.200V*.......: 1.2
CPU PLL…………………....1.500V*.......: 1.5
CPU Referen.…………....0.760V*.......: 0.760
MCH/ICH
MCH Core…………….....1.100V...........: << 1.1
MCH Reference….…….0.760V...........; <<< Auto
MCH/DRAM Ref.…......0.900V...........: <<< Auto
ICH I/O……………….....1.500V............: <<< 1.5
DRAM
DRAM Voltage ……....1.800V............: 1.8
Advanced Settings
