D
Daemium
Guest
I’m planning to upgrade my old PIII-700@1000mhz with a new AMD 1.4ghz with two 256mb corsair 2400 DDR sticks paired with the EPoX EP-8K7A+, but I have some doubts about the mobo.
1. Somebody knows if this mobo is compatible with the future “Athlon 4”? I’m concern about the
apparently impossibility to under voltage the Vcore. Also can be this fixed with a bios upgrade?
2. This mobo really has the 1/5 divider that everybody is talking?
3. I should buy 1 memory stick or two? (going to overclock)
4. Can you completely disable the RAID?
5. Recommended Heat sink?
Any other comments or suggestions are welcome.
Thanks for your help.
