Do you know one, Let me know.
I allready know this one,
Hoc=Hdef(Vnew/Vdef)^2(Snew/Sdef).
Hdef =the defaut heat of your CPU which I'll guess is 15-16Watts more precise can be found on the Intel spec sheet for it.
Vnew is your new voltage,
Vdef is default voltage, and that "^2" is too the power of 2 or just square the answer in those brackets.
Snew is your new CPU speed (1035),
Sdef is your CPU's default speed (633).
but you need to know the ORIGIONAL data first. It is the orgional data I am looking for. I do not want to add all intel and AMD processor specs into a database if there is a simple equation I can do...
