Error in Counter-Strike
oc_newbee
I'm just a noob in CS, I often get an error in the middle of the game saying that there is somekind of loading error and have to hit ok and the whole game just shut off.
I'm playing with pod bot 2.5v and using CS 1.5. Is there a way to get rid of this error?
Thanks in advance.
No one has any input or ever run into a problem like this? Would anyone suggest any setting I should use in CS.
Thanks.
Noticed you're using podbot, your problem is probably related to it. Does the error occur while trying to start the server but before the game starts (before the bots actually load), or in-game with bots active?
If it's the former, then your liblist.gam is probably hosed.
Change this line:
gamedll "dlls\mp.dll"
to:
gamedll "PODbot\podbot.dll"
If the game is simply crashing, your waypoints may be bad, esp. if it's a custom map.
