- May 16, 2012
i have some errors notification on windows log,
1. The machine-default permission settings do not grant Local Activation permission for the COM Server application with CLSID
{C2F03A33-21F5-47FA-B4BB-156362A2F239}
and APPID
{316CDED5-E4AE-4B15-9113-7055D84DCC97}
to the user user-PC\user SID (S-1-5-21-3530305174-994551858-3193261782-1000) from address LocalHost (Using LRPC) running in the application container Microsoft.Windows.Cortana_1.6.1.52_neutral_neutral_cw5n1h2txyewy SID (S-1-15-2-1861897761-1695161497-2927542615-642690995-327840285-2659745135-2630312742). This security permission can be modified using the Component Services administrative tool. Event ID : 10016
2. The egGetSvc service terminated unexpectedly. It has done this 1 time(s). Event ID : 7034
3. The NetTcpActivator service depends on the NetTcpPortSharing service which failed to start because of the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. Event ID : 7001
what should i do to fix it, thx
and APPID
