error?
Amorphus
Central MA
sorry for the whole bunch of threads I'ms tarting about problems I'm having...
anyways, it seems that I can't get through an entire work unit without getting some sort of error (at least, EMIII shows an error. the red flashlight dingy starts blinking, instead of green, and all progress stops. reporting) this most recent one was after finishing frame 62.
anyways, that way, I haven't been able to fully complete a WU since that first one awhile ago. its very frustrating.
is there any way to diagnose this "error"? (the actual FAH console doesn't show anything, and cpu usage is still showing 100... its just EM3 not showing any change in progress and flashing red.)
(well, another frame just got done. it seems EM3 is just being stupid)
Are you overclocked at all? Have you run a memory diagnostic to rule that out? Have you blown the dust out of your system lately to make sure it's not getting too hot?
Check your setup options in EmIII - if the console is still chugging along merrily, then you know exactly where your problems lie :D
