ESXi, anyone use it?
joedymueller
Northern Virginia
I just installed VMware's ESXi on one of my machines, I was able to get it running just fine, but can't figure out how to get any vm machines on to it. All i can do is setup a blank instance that just tries to boot from a network...
I haven't done much reading about it yet, but was looking for some pointers form anyone who has used it.
SuperMiguel
Super User
Florida, US
you have to use a client on another machine.. thats the bad part of esxi you have to use a clicnt, that runs on another machine.
joedymueller
joedymueller
Northern Virginia
yea i have the V sphere? or what ever its called installed and I am able to connect to the ESXi machine from it.. just can't figure out how to get any images or ISO's over to create a usable virtual machine
SuperMiguel
Super User
Florida, US
like i if you just go to the ip that you set in your esxi box, you will be able to download the client..
SuperMiguel
Super User
Florida, US
it should be named vmware infrastructure client.. so you logged in? looks like this:
then you go to: virtual machines and on the left side it says create virtual machine
or in the new version of esxi you use the vsphere client looks like this:
joedymueller
joedymueller
Northern Virginia
yea thats what i got. i was able to create a machine, but I dont see how to install anything on it. it says you can download premade vm's but none that i can see are what i need.
SuperMiguel
Super User
Florida, US
ohhhhh create a Datastore first !!!
select the "Configuration" tab and then click the "Create New Datastore" link to start the "Add Storage" wizard
then go back to summary and you will see New "Virtual Machine"
joedymueller
joedymueller
Northern Virginia
im at work right now. so i cant check it. I see a datasote there thats the full size of my HD. do i need to create another one from that? or is that what i use?
SuperMiguel
Super User
Florida, US
thats what you use.. but by default there is no datastore, you you need to create one, then go back to summary and you will see New "Virtual Machine"
