So Evga makes several versions of the same 1070 card. They change the cooling, lighting, looks and to some extent the overclock, but they are all more or less the same base 1070 GPU. However, the listed power requirements vary greatly from the lower end models requiring 150W to the higher end models requiring 215W. The low end models use one 8 pin connector and the higher models use two. Now I know a card with a higher clock rate will use more power and the different cooling methods might use a watt or two more compared to each other, but there is no way in heck that a ~70 Mhz. difference in core clock speed is going to account for a 75W increase in power. So why is there such a huge difference? Look at the below link for more info:
http://www.evga.com/products/product.aspx?pn=08G-P4-5171-KR
