- Feb 4, 2017
- Marion, IA
Alright guys, I have an EVGA 1080 FTW Hybrid that I have fitted a Vardar fan to (runs at 100% @ 40*c and over) and it seems to be running hotter than it should IMHO. I will see temps in the 48*c to 52*c temp zone while running Valley with a slight overclock and 1.063 volts on the core. Does anyone thing that removing the pump and applying either liquid ultra or Arctic MX-4 would help with this? Is it just a limitation with the stock cooling system?
I would think that it would run cooler than this. System temp usually runs around 32-33*c as measured by the MoBo's on board temp sensor.
Thanks in advance!
Thanks in advance!
