Hi.
I was hoping that anyone had any additional insight into my current situation. I have been dealing with this system for the past week and a half and I am about to cut my losses and make a dramatic switch in hardware.
Problem: The computer locks up anywhere from 2 minutes to 2 hours during any game play or 3D benchmark. This never occurs during memory testing, CPU stress, idle or 2D applications. The screen is completely frozen and occasionally, the sound card will “pop” and/or repeat the current sound that occurred during the lock up itself. The computer doesn’t respond to Ctl-Alt-Del and the computer must be reset. If the power button is held for 5 seconds while the lock up occurs, the computer will shut off and never turn on again, until the power is completely shut off at the PSU itself.
The Computer (simple):
Opteron 165, 2GB memory, single eVGA 7800 256MB, 2 WD Raptors (RAID 0), adequate PSU
The Computer (verbose):
Case: Cooler Master Centurion case (decent airflow, CompUSA had a special)
Case Fans: 3 MadDog 60 CFM 24dBA Fans. Located at front (passing through the Hard drives), rear and in a drive bay aimed at the RAM itself.
PSU: Sin-Tek WIN550XSPX-X 500W Power Supply (SLI capable)
PSU: BFG BFGR600WPSU 600W Power Supply (SLI capable)
NOTE: Currently using BFG supply. I swapped supplies to see if I got a different result. I did not. I didn’t bother putting the Sin-Tek back in until I solve the problem as I spent 30-40 minutes wire tying the darned thing.
Motherboard: DFI LanParty UT nF4 SLI-DR Expert
CPU: Opteron 165 Dual Core 1.8GHz (0550)
CPU Heatsink: Thermaltake 4-in-1 Big Typhoon
RAM: OCZ5002048ELGEGXT-K PC4000 2G(2x1024) DDR500 EL GOLD GAMER EXT XTC
Video Card (setup #1): 2 eVGA e-GeForce 7800 GT OC (256-P2-N517-AX) in SLI mode
Video Card (setup #2 and 3): Single eVGA e-GeForce 7800 GT OC (256-P2-N517-AX)
NOTE: I was getting blue screens left and right even when the computer was idle while using SLI mode. Turns out, as I discovered in Video card setup #3, that one of the video cards had faulty RAM. When I plugged the bad card in by itself, the BIOS prompt had funny characters all over it.
Hard Drive (setup #1): Western Digital 36GB Raptor 10k RPM SATA
Hard Drive (setup #2): 2 Western Digital 36GB Raptor 10k RPM SATA (RAID 0)
NOTE: When originally setting up the computer I was setting it up as a RAID 0. During a SuperPi 32M test the computer locked up. When I rebooted one of the hard drives was clicking away. I suspect that the drive had an electrical problem which caused the computer to crash. Needless to say, while I waited for my replacement I had the same symptoms with a single drive set up. I am now, once again, running a RAID 0 setup.
Sound Card: Creative X-Fi XtremeMusic
Sound Card: On-board A97
NOTE: The X-Fi itself was giving me some blue screens in Battlefield2. Turns out that there are some issues with the X-Fi card. So, instead of trying to troubleshoot two problems at once I removed it and used the motherboard sound. Both configurations have the same lockup problem though.
Network Card: On-board Network
DVD/CD Burner: Currently unplugged
Floppy Drive: Currently unplugged
Keyboard: Zboard originally. Now using standard MS keyboard (PS/2)
Mouse: Logitec G7 Wireless Laser mouse originally. Now using standard MS 3 button mouse (PS/2)
Configuration:
CPU: Both 1.8GHz (stock) and 2.5GHz (overclocked). Currently 1.8GHz
Memory: Both 200MHz/DDR 400 (below stock) and 252MHz/DDR504 (slightly above stock, in spec). Currently 200MHz/DDR400. Memory is running in Dual channel 1T.
LDR/FSB dividers: I have tried all options that keep me under a total of 1000MHz.
Voltages: Tested both at spec and slightly above spec for extra stability. Both give same results.
PCI-e Motherboard setup: I made sure that when in SLI mode 8/8 speeds were selected and when not in SLI mode 16x was selected.
On Board devices: Originally, I had all of the devices enabled. However, as of right now, they are pretty much all disabled except for nVidia LAN, nVidia RAID and the on-board sound. USB is even completely disabled. No difference.
BIOS: Latest and greatest BIOS version for both DFI motherboard and eVGA graphics card.
MB Drivers: 6.66 (came with MB) and 6.70. With and without SW drivers, IDE drivers and Network Firewall software. All resulted in same problems.
Video Drivers: 81.85 (came with Video card) and 81.98. I noticed in the release notes for 81.98 a section about instability with Dual Core processors and the latest nVidia Forceware drivers. The work around disables the multiple threads of the Forceware drivers. I have tried both with and without the Dual Core workaround for both OpenGL and DirectX.
Additional Info: AMD Driver and MS Hotfix for Dual Core CPUs have been installed.
Tests:
MemTest86: Test 5 (5 complete sequences), Test 8 (5 complete sequences), Tests 1-8 (10 complete sequences), Tests 1-8 (24 hours) – All completed successfully with no errors.
SuperPi 32M: Completed the tests multiple times on Core 0, Core 1 and on both Core 0 and Core 1 simultaneously. Only once crashed, however, at that moment one of the hard drives had an electrical failure. The hard drive no longer worked after and was replaced. Since then, I never had an issue with SuperPi 32M again.
Prime95: Small FFTs, In-Place Large FFTs and Blend ran successfully multiple times on both Cores.
Configuration:
Tests:
