I'm not sure what your question is, are you looking for recommendation of an exact model number? A 1070 is a 1070, you will be paying for a different cooler or stock overclock (and possibly a different VRM section). I'd just get one with the ACX cooler and call it a day.
I'm after a 1070 card but not sure what brand might be best for me, whether it be EVDA, Asus, MSI...
For some odd reason I think I prefer EVGAbut would like to hear what you guys think in terms of best graphic card for video editing
Thanks in advance.
As Janus stated, all the GTX 1070 will handle your editing pretty much the same. If you're looking for something with a factory overclock or a certain look/color, then go with one of those cards. The EVGA is pretty popular, and they have great warranty support so you won't be disappointed with them. EVGA has many options in the GTX 1070 line-up, any of them would be a great option: EVGA GTX 1070
I thought the GPU makes a small difference when it comes to encoding. I thought the CPU does the majority of work, so would a 1070 even be necessary? Could OP save some money and go with a 1060 or 1050ti and spend the money on a better cpu with better encoding results?
That depends on the program and what type of encoding is being done.
No worries man. Enjoy the card.
None that I know of.I'm in the same situation (video rendering with Adobe Premier) and looking at the same card (gtx1070). There are a ton of these available at Newegg. Is there any likelihood of a significant price drop to make it worth a wait?
Maybe some of the manufactures will have some deals going on but that's all I know of.None that I know of.
Glad someone was counting.![]()
