Posted this over on EVGA's forums as well but I figured the more lines I cast, the better chance of getting a bite.
I purchased this many months ago and installed it on a TR 1950X but promptly removed it as I wasn't happy with cooling performance since it didn't completely cover the dice under the heatspreader. Now I am building a computer for someone else and was going to use it since this build is just AM4 and I was probably never going to use the cooler. It was shipped with the AM4 standoffs and mounting bracket in the box so I didn't have to request them separately. The problem is, when following the instructions exactly, it doesn't fit properly. I removed the 2 plastic retention clips and , using the stock backplate for the motherboard, screwed the 4 standoffs specific to the AM4 application (they look very different than the rest) into the backplate's threads which stick through the 4 holes around the cpu socket. the problem is that the 4 female threaded posts of the backplate bottom out in the standoffs "cup" well before the standoff and backplate form a tight seal on the motherboard so what happens is the pump gets bolted down to the standoffs using the AM4 mounting bracket, but can then slip and slide all over the cpu's heatspreader because it can't tighten down firm because of all the play in the backplate. I just got off the phone with Matthew at EVGA who suggested going to store.asetek.com where i could find the part itself as well as the instructions, but I have all of the parts and i followed those instructions and it still a poor fit (thermals would be god awful if it didn't just shut down on it's own). The motherboard is an ASUS ROG Strix X470-F Gaming. Does anyone know what i might be doing wrong? Thanks!
