Joeteck
Retired
- Oct 5, 2001
- Long Island
WHY?
Extreme overclocking when you need to have fine control over voltages in your hardware to squeeze that last little bit of performance out. Probably most often used in conjunction with extreme cooling when not having to go back into the bios to make adjustments would be helpful, and probably more control than using a program in your OS to make the adjustments.
However, for only a handful of EVGA boards.... seems silly...
For those boards that can use it, it seems like a useful tool for benching. And it just came out...I expect to see more boards that will eventually make use of it, or something like it.
Note that someone was able to mod it to work on an ASUS ATI card:
http://kingpincooling.com/forum/showthread.php?p=1694#post1694
Also, why does it seem silly?
I dunno... Something about a tool to do the job of an experienced overclocker. This thing takes the science and experience and puts it in a piece of hardware...
Like using a calculator to do simple math...
It does the same thing as the BIOS does though...its adjust voltages, FSB, etc on the fly in windows. It doesnt take the science or the experience out of it as the same process is still used as far as finding the right voltages and experimenting. It doesnt do the work for you like a calculator. Think of it like counting on your fingers and writing it out...
A good example of why this works, especially for the extreme crowd or those that hit a wall (me)... I cannot push past 523FSB (4.707Ghz) with my BIOS settings. The use of this tool and other windows based utilities like SetFSB/Asus EasyTune6 allowed me to push right through that. Im not sure why/how that specifically works, but I know the "Pros" use those tools seemingly to push past FSB walls. In fact, I just started a thread a couple of days ago in the benching lounge and aside from some voltage suggestions, they said to use SetFSB and it worked. Gautam said it gets the last xxxMhz out of your rig.
I have not used it, no. However its clear how it works and what it accomplishes over BIOS overclocking. There are other tools just like it (from Asus?). What are you suggesting I am guessing at? Am I mistaking? Did I misread the article now and a month ago?
Torin has done a more than admirable job in filling in any blanks on its usage.
Your first post wasnt looking for specifics that required the actual use of the product so I replied with what knowledge I have from reading the product page the day it came out, as well as other posts at other sites where people have used it (Evga, XS, etc) and also using the windows based tools it is quite similar to. You asked "why?", and I knew why, so I replied. Judging by word choice Torin used, "It just seems like" and "I can see it allowing...." he hasnt used it either. So why single me out??? Anyway, I am an avid bencher and reasearched items like this before. Not to mention, in the benching lounge, there are a couple of threads on this. So I shared the knowledge I learned. Thats what forums are all about.Alot of members just reply for the sake of replying and really have no idea what they're talking about...
Sorry I missed that point. Though like I mentioned, Asus(?) Has a similar tool, though it doesnt seem as encompassing.Anyway... the point was that its only used for a few EVGA boards and nothing else. SO you're SOL if you had Gigabyte board... and wanted to get it.
I have an EVGA GTX 285 Classified and Im not sure the EVBOT would be worth it for GPU only.
I dont bench so for my app. doesnt seem like I will ever need it.
Unless Im missing something?
