- Mar 14, 2013
- Massachusetts
EVGA Z390 Dark & Lian Li PC-V3000 Build Log
The build I've been planning since September is complete! Design thread here! I have a bunch of comments specifically about the Lian case that I hope folks may find useful. Will post em after the pics.
Much appreciated to everyone who contributed and commented in my design thread.
CORE COMPONENTS
WATER COOLING COMPONENTS
CPU Block: EK Velocity Full Nickel RGB
2 x EVGA Hydrocopper GPU Waterblocks
Pump: EK Dual D5 Pump
Reservoir: EK 250 Lite
Radiators: Alphacool 2 x 360mm UT60 & 1 x 480mm UT60
Tubing: PrimoChill Advanced LRT w/ 3 x Silver Kill Coils in the tubing
Fittings: Bitspower, Enzotech, Koolance QD
Fans: Noctua 120mm iPPC 2000RPM on top and front radiators. Akasa 120mm Vipers on bottom radiator.
FINAL RESULT!!!
2 x 2080Ti FTW3 Ultra Hydrocoppers added to loop. Additional changes made while adding GPUs...
Bitspower On/Off Valve added to bottom of GPUs. This gives a drainage solution at the two lowest points in the build
Rerouted top tubing route to run to the side of the top radiator as opposed to below it. Gives better access to radiator fans, RAM, and the reservoir fill port
Swapped out pump's white PWM connectors with black ones to blend in better with the motherboard and overall build
Better organization of GPU power cables, added cable combs
Final Result pre GPUs added to loop
Opening the Case. I originally posted these pictures in the design thread.
The first thing I needed to do was cut out some metal and a drill a hole for the tubing run and radiator placement.
I'm very surprised that Lian left this covered by default. Makes perfect sense to keep it open for tubing. Used the average dremmel to cut it out. I actually abandoned the below fitting and drainage design and instead just went with a pair of Koolance QD3 Quick Disconnects. Way simpler overall to just take a spare piece of tubing with a spare female QD I bought.
For allowing the rear fitting of the front radiator to connect to the fitting exposed by the above cut out. Used a step drill bit, was actually really easy.
Also sleeved the cables on the EK Dual Pump. Very surprised that this isn't standard from EK. It's their most expensive pump setup and they sleeve other pumps. Odd omission.
CORE COMPONENTS
- Case: Lian LI PC-V3000WX
- Mobo: EVGA Z390 Dark
- CPU: Intel i9900k Delidded from Silicon Lottery. Binned at 5.0 GHz.
- GPU 2 x EVGA 2080Ti FTW3 Ultra Hydrocopper NVLink SLI
- RAM: G.Skill Trident Z RGB @ 4,133 MHz 17-17-17-37
- SSD 1: Samsung 970 Pro 512 GB for Boot, Drivers, Critical Programs and Monitoring Programs
- SSD 2: Samsung 970 Evo 500 GB for general programs and games
- SSD 3: Samsung 850 Evo 1 TB for general storage
- PSU: EVGA Supernova 1600w T2
FINAL RESULT!!!
