- Feb 25, 2004
- Folding @ Eagle Rock, CA
Thanks to harlam's HFM monitoring tool, I discovered that my 8600GTS has been getting a lot of UNSTABLE_MACHINE errors. It doesn't seem to be the NANS problem since I'm not getting any messages that say "NANs detected on GPU".
ATITool's check for artifacts has been running for 4 hours with no errors. Also, I can play Empire Total War, Left 4 Dead, or World of Warcraft for at least 2 hours without crashing or anything.
Temps are around 55C, which I realize might be on the high side, but from what I've read it's not bad.
I don't have a multimeter to check the rails on my PSU, but I'm fairly confident in it. It's an Antec Neo 550, bought less than 6 months ago. The rest of the components are a Q9550 @ 1.35v, 4 sticks of DDR2 @ 2.2v, and two 7200 RPM SATA hard drives.
Anyone have any ideas as to what could be causing my card to experience UNSTABLE_MACHINE excessively?
Code:
--- Opening Log file [May 15 23:36:08 UTC]
# Windows GPU Console Edition #################################################
Folding@Home Client Version 6.23
http://folding.stanford.edu
Launch directory: C:\Folding@Home\GPU
Executable: C:\Folding@Home\GPU\fah.exe
Arguments: -verbosity 9
[23:36:08] - Ask before connecting: No
[23:36:08] - User name: T32monkeys (Team 32)
[23:36:08] - User ID: 66A71C252D8977C1
[23:36:08] - Machine ID: 2
[23:36:08]
[23:36:08] Loaded queue successfully.
[23:36:08]
[23:36:08] - Autosending finished units... [May 15 23:36:08 UTC]
[23:36:08] Trying to send all finished work units
[23:36:08] + No unsent completed units remaining.
[23:36:08] + Processing work unit
[23:36:08] - Autosend completed
[23:36:08] Core required: FahCore_11.exe
[23:36:08] Core found.
[23:36:08] Working on queue slot 02 [May 15 23:36:08 UTC]
[23:36:08] + Working ...
[23:36:08] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 5892 -version 623'
[23:36:08]
[23:36:08] *------------------------------*
[23:36:08] Folding@Home GPU Core - Beta
[23:36:08] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[23:36:08]
[23:36:08] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:36:08] Build host: amoeba
[23:36:08] Board Type: Nvidia
[23:36:08] Core :
[23:36:08] Preparing to commence simulation
[23:36:08] - Looking at optimizations...
[23:36:08] - Files status OK
[23:36:08] - Expanded 98729 -> 492276 (decompressed 498.6 percent)
[23:36:08] Called DecompressByteArray: compressed_data_size=98729 data_size=492276, decompressed_data_size=492276 diff=0
[23:36:08] - Digital signature verified
[23:36:08]
[23:36:08] Project: 5751 (Run 13, Clone 298, Gen 273)
[23:36:08]
[23:36:08] Assembly optimizations on if available.
[23:36:08] Entering M.D.
[23:36:14] Will resume from checkpoint file
[23:36:15] Working on Protein
[23:36:17] Client config found, loading data.
[23:36:17] Starting GUI Server
[23:36:17] Resuming from checkpoint
[23:36:17] Verified work/wudata_02.log
[23:36:18] Verified work/wudata_02.edr
[23:36:18] Verified work/wudata_02.xtc
[23:36:18] Completed 18%
[23:43:30] Completed 19%
[23:50:48] Completed 20%
[23:58:05] Completed 21%
[00:05:17] Completed 22%
[00:12:30] Completed 23%
[00:19:43] Completed 24%
[00:26:58] Completed 25%
[00:34:23] Completed 26%
[00:41:38] Completed 27%
[00:48:51] Completed 28%
[00:56:03] Completed 29%
[01:03:15] Completed 30%
[01:10:28] Completed 31%
[01:17:40] Completed 32%
[01:24:52] Completed 33%
[01:32:04] Completed 34%
[01:39:17] Completed 35%
[01:46:28] Completed 36%
[01:53:48] Completed 37%
[02:01:16] Completed 38%
[02:08:45] Completed 39%
[02:16:02] Completed 40%
[02:23:18] Completed 41%
[02:30:31] Completed 42%
[02:37:43] Completed 43%
[02:44:55] Completed 44%
[02:52:05] Completed 45%
[02:59:16] Completed 46%
[03:06:27] Completed 47%
[03:13:40] Completed 48%
[03:20:51] Completed 49%
[03:28:03] Completed 50%
[03:35:15] Completed 51%
[03:42:31] Completed 52%
[03:49:43] Completed 53%
[03:56:55] Completed 54%
[04:04:07] Completed 55%
[04:11:19] Completed 56%
[04:18:31] Completed 57%
[04:25:42] Completed 58%
[04:32:57] Completed 59%
[04:40:11] Completed 60%
[04:47:24] Completed 61%
[04:54:35] Completed 62%
[05:01:47] Completed 63%
[05:09:00] Completed 64%
[05:16:16] Completed 65%
[05:23:29] Completed 66%
[05:30:40] Completed 67%
[05:36:05] - Autosending finished units... [May 16 05:36:05 UTC]
[05:36:05] Trying to send all finished work units
[05:36:05] + No unsent completed units remaining.
[05:36:05] - Autosend completed
[05:37:55] Completed 68%
[05:45:08] Completed 69%
[05:52:19] Completed 70%
[05:59:30] Completed 71%
[06:06:42] Completed 72%
[06:13:55] Completed 73%
[06:21:08] Completed 74%
[06:28:33] Completed 75%
[06:35:49] Completed 76%
[06:43:07] Completed 77%
[06:48:26] Run: exception thrown during GuardedRun
[06:48:26] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[06:48:26] Going to send back what have done -- stepsTotalG=10000000
[06:48:26] Work fraction=0.7773 steps=10000000.
[06:48:30] logfile size=13406 infoLength=13406 edr=0 trr=23
[06:48:30] - Writing 13942 bytes of core data to disk...
[06:48:30] Done: 13430 -> 4348 (compressed to 32.3 percent)
[06:48:30] ... Done.
[06:48:31]
[06:48:31] Folding@home Core Shutdown: EARLY_UNIT_END
[06:48:34] CoreStatus = 72 (114)
[06:48:34] Sending work to server
[06:48:34] Project: 5751 (Run 13, Clone 298, Gen 273)
[06:48:34] - Read packet limit of 540015616... Set to 524286976.
[06:48:34] + Attempting to send results [May 16 06:48:34 UTC]
[06:48:34] - Reading file work/wuresults_02.dat from core
[06:48:34] (Read 4860 bytes from disk)
[06:48:34] Connecting to http://171.67.108.11:8080/
[06:48:34] Posted data.
[06:48:34] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[06:48:34] - Uploaded at ~11 kB/s
[06:48:34] - Averaged speed for that direction ~12 kB/s
[06:48:34] + Results successfully sent
[06:48:34] Thank you for your contribution to Folding@Home.
[06:48:38] Trying to send all finished work units
[06:48:38] + No unsent completed units remaining.
[06:48:38] - Preparing to get new work unit...
[06:48:38] + Attempting to get work packet
[06:48:38] - Will indicate memory of 8190 MB
[06:48:38] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 10
[06:48:38] - Connecting to assignment server
[06:48:38] Connecting to http://assign-GPU.stanford.edu:8080/
[06:48:39] Posted data.
[06:48:39] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[06:48:39] + News From Folding@Home: GPU folding beta
[06:48:39] Loaded queue successfully.
[06:48:39] Connecting to http://171.67.108.11:8080/
[06:48:39] Initial: 0000; - Receiving payload (expected size: 99305)
[06:48:39] Conversation time very short, giving reduced weight in bandwidth avg
[06:48:39] - Downloaded at ~193 kB/s
[06:48:39] - Averaged speed for that direction ~121 kB/s
[06:48:39] + Received work.
[06:48:39] Trying to send all finished work units
[06:48:39] + No unsent completed units remaining.
[06:48:39] + Closed connections
[06:48:44]
[06:48:44] + Processing work unit
[06:48:44] Core required: FahCore_11.exe
[06:48:44] Core found.
[06:48:44] Working on queue slot 03 [May 16 06:48:44 UTC]
[06:48:44] + Working ...
[06:48:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 5892 -version 623'
[06:48:44]
[06:48:44] *------------------------------*
[06:48:44] Folding@Home GPU Core - Beta
[06:48:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:48:44]
[06:48:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:48:44] Build host: amoeba
[06:48:44] Board Type: Nvidia
[06:48:44] Core :
[06:48:44] Preparing to commence simulation
[06:48:44] - Looking at optimizations...
[06:48:44] - Created dyn
[06:48:44] - Files status OK
[06:48:44] - Expanded 98793 -> 492276 (decompressed 498.2 percent)
[06:48:44] Called DecompressByteArray: compressed_data_size=98793 data_size=492276, decompressed_data_size=492276 diff=0
[06:48:44] - Digital signature verified
[06:48:44]
[06:48:44] Project: 5750 (Run 5, Clone 16, Gen 331)
[06:48:44]
[06:48:44] Assembly optimizations on if available.
[06:48:44] Entering M.D.
[06:48:51] Working on Protein
[06:48:53] Client config found, loading data.
[06:48:53] Starting GUI Server
[06:57:08] Completed 1%
[07:04:19] Completed 2%
[07:11:32] Completed 3%
[07:18:44] Completed 4%
[07:25:57] Completed 5%
[07:33:10] Completed 6%
[07:40:24] Completed 7%
[07:47:37] Completed 8%
[07:54:50] Completed 9%
[08:02:04] Completed 10%
[08:09:16] Completed 11%
[08:16:28] Completed 12%
[08:23:40] Completed 13%
[08:30:53] Completed 14%
[08:38:05] Completed 15%
[08:44:16] ***** Got a SIGTERM signal (2)
[08:44:16] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [May 16 09:49:41 UTC]
[09:49:41] - Ask before connecting: No
[09:49:41] - User name: T32monkeys (Team 32)
[09:49:41] - User ID: 66A71C252D8977C1
[09:49:41] - Machine ID: 2
[09:49:41]
[09:49:42] Loaded queue successfully.
[09:49:42]
[09:49:42] + Processing work unit
[09:49:42] - Autosending finished units... [May 16 09:49:42 UTC]
[09:49:42] Core required: FahCore_11.exe
[09:49:42] Trying to send all finished work units
[09:49:42] + No unsent completed units remaining.
[09:49:42] - Autosend completed
[09:49:42] Core found.
[09:49:42] Working on queue slot 03 [May 16 09:49:42 UTC]
[09:49:42] + Working ...
[09:49:42] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 4588 -version 623'
[09:49:42]
[09:49:42] *------------------------------*
[09:49:42] Folding@Home GPU Core - Beta
[09:49:42] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:49:42]
[09:49:42] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:49:42] Build host: amoeba
[09:49:42] Board Type: Nvidia
[09:49:42] Core :
[09:49:42] Preparing to commence simulation
[09:49:42] - Looking at optimizations...
[09:49:42] - Files status OK
[09:49:42] - Expanded 98793 -> 492276 (decompressed 498.2 percent)
[09:49:42] Called DecompressByteArray: compressed_data_size=98793 data_size=492276, decompressed_data_size=492276 diff=0
[09:49:42] - Digital signature verified
[09:49:42]
[09:49:42] Project: 5750 (Run 5, Clone 16, Gen 331)
[09:49:42]
[09:49:42] Assembly optimizations on if available.
[09:49:42] Entering M.D.
[09:49:48] Will resume from checkpoint file
[09:49:48] Working on Protein
[09:49:51] Client config found, loading data.
[09:49:51] Starting GUI Server
[09:49:51] Resuming from checkpoint
[09:49:51] Verified work/wudata_03.log
[09:49:51] Verified work/wudata_03.edr
[09:49:51] Verified work/wudata_03.xtc
[09:49:51] Completed 15%
[09:57:00] Completed 16%
[10:04:10] Completed 17%
[10:11:21] Completed 18%
[10:18:30] Completed 19%
[10:25:39] Completed 20%
[10:32:48] Completed 21%
[10:38:36] Run: exception thrown during GuardedRun
[10:38:36] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[10:38:36] Going to send back what have done -- stepsTotalG=10000000
[10:38:36] Work fraction=0.2181 steps=10000000.
[10:38:40] logfile size=13007 infoLength=13007 edr=0 trr=23
[10:38:40] - Writing 13543 bytes of core data to disk...
[10:38:40] Done: 13031 -> 4280 (compressed to 32.8 percent)
[10:38:40] ... Done.
[10:38:41]
[10:38:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:38:44] CoreStatus = 7A (122)
[10:38:44] Sending work to server
[10:38:44] Project: 5750 (Run 5, Clone 16, Gen 331)
[10:38:44] - Read packet limit of 540015616... Set to 524286976.
[10:38:44] + Attempting to send results [May 16 10:38:44 UTC]
[10:38:44] - Reading file work/wuresults_03.dat from core
[10:38:44] (Read 4792 bytes from disk)
[10:38:44] Connecting to http://171.67.108.11:8080/
[10:38:44] Posted data.
[10:38:44] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[10:38:44] - Uploaded at ~11 kB/s
[10:38:44] - Averaged speed for that direction ~12 kB/s
[10:38:44] + Results successfully sent
[10:38:44] Thank you for your contribution to Folding@Home.
[10:38:48] Trying to send all finished work units
[10:38:48] + No unsent completed units remaining.
[10:38:48] - Preparing to get new work unit...
[10:38:48] + Attempting to get work packet
[10:38:48] - Will indicate memory of 8190 MB
[10:38:48] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 10
[10:38:48] - Connecting to assignment server
[10:38:48] Connecting to http://assign-GPU.stanford.edu:8080/
[10:38:49] Posted data.
[10:38:49] Initial: 40AB; - Successful: assigned to (171.64.122.70).
[10:38:49] + News From Folding@Home: GPU folding beta
[10:38:49] Loaded queue successfully.
[10:38:49] Connecting to http://171.64.122.70:8080/
[10:38:50] Posted data.
[10:38:50] Initial: 0000; - Receiving payload (expected size: 70653)
[10:38:50] Conversation time very short, giving reduced weight in bandwidth avg
[10:38:50] - Downloaded at ~137 kB/s
[10:38:50] - Averaged speed for that direction ~123 kB/s
[10:38:50] + Received work.
[10:38:50] Trying to send all finished work units
[10:38:50] + No unsent completed units remaining.
[10:38:50] + Closed connections
[10:38:55]
[10:38:55] + Processing work unit
[10:38:55] Core required: FahCore_14.exe
[10:38:55] Core found.
[10:38:55] Working on queue slot 04 [May 16 10:38:55 UTC]
[10:38:55] + Working ...
[10:38:55] - Calling '.\FahCore_14.exe -dir work/ -suffix 04 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 4588 -version 623'
[10:38:55]
[10:38:55] *------------------------------*
[10:38:55] Folding@Home GPU Core - Beta
[10:38:55] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[10:38:55]
[10:38:55] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:38:55] Build host: vspm46
[10:38:55] Board Type: Nvidia
[10:38:55] Core :
[10:38:55] Preparing to commence simulation
[10:38:55] - Looking at optimizations...
[10:38:55] - Created dyn
[10:38:55] - Files status OK
[10:38:55] - Expanded 70141 -> 360060 (decompressed 513.3 percent)
[10:38:55] Called DecompressByteArray: compressed_data_size=70141 data_size=360060, decompressed_data_size=360060 diff=0
[10:38:55] - Digital signature verified
[10:38:55]
[10:38:55] Project: 5900 (Run 11, Clone 469, Gen 63)
[10:38:55]
[10:38:55] Assembly optimizations on if available.
[10:38:55] Entering M.D.
[10:39:01] Tpr hash work/wudata_04.tpr: 2566526281 1909324625 4066228816 1259798397 734441316
[10:39:02] Working on Protein
[10:39:03] Client config found, loading data.
[10:39:03] Starting GUI Server
[10:42:12] Completed 1%
[10:46:59] Completed 2%
[10:51:52] Completed 3%
[10:56:42] Completed 4%
[11:01:26] Completed 5%
[11:06:06] Completed 6%
[11:10:55] Completed 7%
[11:15:31] Completed 8%
[11:20:30] Completed 9%
[11:25:31] Completed 10%
[11:30:21] Completed 11%
[11:34:58] Completed 12%
[11:39:17] Completed 13%
[11:44:19] Completed 14%
[11:49:26] Completed 15%
[11:54:26] Completed 16%
[11:58:56] Completed 17%
[12:03:41] Completed 18%
[12:08:23] Completed 19%
[12:13:42] Completed 20%
[12:18:26] Completed 21%
[12:23:51] Completed 22%
[12:28:57] Completed 23%
[12:33:22] Completed 24%
[12:37:55] Completed 25%
[12:42:43] Completed 26%
[12:47:26] Completed 27%
[12:52:13] Completed 28%
[12:57:03] Completed 29%
[13:01:30] Completed 30%
[13:06:08] Completed 31%
[13:10:51] Completed 32%
[13:15:40] Completed 33%
[13:20:33] Completed 34%
[13:25:18] Completed 35%
[13:31:15] Completed 36%
[13:36:16] Completed 37%
[13:41:01] Completed 38%
[13:45:39] Completed 39%
[13:50:58] Completed 40%
[13:55:51] Completed 41%
[14:00:38] Completed 42%
[14:05:32] Completed 43%
[14:10:25] Completed 44%
[14:15:20] Completed 45%
[14:20:05] Completed 46%
[14:24:33] Completed 47%
[14:29:15] Completed 48%
[14:34:04] Completed 49%
[14:38:46] Completed 50%
[14:42:44] Completed 51%
[14:47:17] Completed 52%
[14:51:53] Completed 53%
[14:57:20] Completed 54%
[15:01:56] Completed 55%
[15:06:41] Completed 56%
[15:11:28] Completed 57%
[15:16:23] Completed 58%
[15:21:23] Completed 59%
[15:27:45] Completed 60%
[15:32:47] Completed 61%
[15:37:16] Completed 62%
[15:41:56] Completed 63%
[15:46:54] Completed 64%
[15:49:39] - Autosending finished units... [May 16 15:49:39 UTC]
[15:49:39] Trying to send all finished work units
[15:49:39] + No unsent completed units remaining.
[15:49:39] - Autosend completed
[15:51:33] Completed 65%
[15:55:59] Completed 66%
[16:01:05] Completed 67%
[16:06:02] Completed 68%
[16:06:48] ***** Got a SIGTERM signal (2)
[16:06:48] Killing all core threads
--- Opening Log file [May 16 16:46:18 UTC]
[16:46:20] - Ask before connecting: No
[16:46:20] - User name: T32monkeys (Team 32)
[16:46:21] - User ID: 66A71C252D8977C1
[16:46:21] - Machine ID: 2
[16:46:21]
[16:46:21] Loaded queue successfully.
[16:46:21]
[16:46:21] - Autosending finished units... [May 16 16:46:21 UTC]
[16:46:22] + Processing work unit[16:46:22] Trying to send all finished work units
[16:46:22] Core required: FahCore_14.exe
[16:46:23] + No unsent completed units remaining.
[16:46:23] Core found.
[16:46:23] - Autosend completed
[16:46:23] Working on queue slot 04 [May 16 16:46:23 UTC]
[16:46:24] + Working ...
[16:46:24] - Calling '.\FahCore_14.exe -dir work/ -suffix 04 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[16:46:25]
[16:46:26] *------------------------------*
[16:46:26] Folding@Home GPU Core - Beta
[16:46:26] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[16:46:27]
[16:46:27] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:46:28] Build host: vspm46
[16:46:28] Board Type: Nvidia
[16:46:28] Core :
[16:46:28] Preparing to commence simulation
[16:46:28] - Looking at optimizations...
[16:46:28] - Files status OK
[16:46:29] - Expanded 70141 -> 360060 (decompressed 513.3 percent)
[16:46:29] Called DecompressByteArray: compressed_data_size=70141 data_size=360060, decompressed_data_size=360060 diff=0
[16:46:29] - Digital signature verified
[16:46:29]
[16:46:29] Project: 5900 (Run 11, Clone 469, Gen 63)
[16:46:30]
[16:46:30] Assembly optimizations on if available.
[16:46:30] Entering M.D.
[16:46:35] Will resume from checkpoint file
[16:46:43] Tpr hash work/wudata_04.tpr: 2566526281 1909324625 4066228816 1259798397 734441316
[16:47:05] Working on Protein
[16:47:06] Client config found, loading data.
[16:47:06] Resuming from checkpoint
[16:47:06] fcCheckPointResume: retrieved and current tpr file hash:
[16:47:06] 0 2566526281 2566526281
[16:47:06] 1 1909324625 1909324625
[16:47:06] 2 4066228816 4066228816
[16:47:06] 3 1259798397 1259798397
[16:47:06] 4 734441316 734441316
[16:47:06] Verified work/wudata_04.log
[16:47:06] Verified work/wudata_04.edr
[16:47:06] Starting GUI Server
[16:47:06] Verified work/wudata_04.xtc
[16:47:06] Completed 68%
[16:49:49] Completed 69%
[16:55:00] Completed 70%
[16:59:56] Completed 71%
[17:04:52] Completed 72%
[17:09:48] Completed 73%
[17:14:38] Completed 74%
[17:19:28] Completed 75%
[17:24:18] Completed 76%
[17:29:04] Completed 77%
[17:33:50] Completed 78%
[17:38:35] Completed 79%
[17:43:19] Completed 80%
[17:48:04] Completed 81%
[17:52:57] Completed 82%
[17:57:49] Completed 83%
[18:02:41] Completed 84%
[18:07:25] Completed 85%
[18:12:14] Completed 86%
[18:17:02] Completed 87%
[18:22:05] Completed 88%
[18:26:51] Completed 89%
[18:31:41] Completed 90%
[18:36:31] Completed 91%
[18:41:16] Completed 92%
[18:46:05] Completed 93%
[18:50:54] Completed 94%
[18:55:42] Completed 95%
[19:00:28] Completed 96%
[19:05:22] Completed 97%
[19:10:16] Completed 98%
[19:15:02] Completed 99%
[19:19:53] Completed 100%
[19:19:56] Successful run
[19:19:56] DynamicWrapper: Finished Work Unit: sleep=10000
[19:20:06] Reserved 11304 bytes for xtc file; Cosm status=0
[19:20:06] Allocated 11304 bytes for xtc file
[19:20:06] - Reading up to 11304 from "work/wudata_04.xtc": Read 11304
[19:20:06] Read 11304 bytes from xtc file; available packet space=786419160
[19:20:06] xtc file hash check passed.
[19:20:06] Reserved 23472 23472 786419160 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[19:20:06] Allocated 23472 bytes for arc file
[19:20:06] - Reading up to 23472 from "work/wudata_04.trr": Read 23472
[19:20:06] Read 23472 bytes from arc file; available packet space=786395688
[19:20:06] trr file hash check passed.
[19:20:06] Allocated 560 bytes for edr file
[19:20:06] Read bedfile
[19:20:06] edr file hash check passed.
[19:20:06] Allocated 114805 bytes for logfile
[19:20:06] Read logfile
[19:20:06] GuardedRun: success in DynamicWrapper
[19:20:06] GuardedRun: done
[19:20:06] Run: GuardedRun completed.
[19:20:06] - Writing 150653 bytes of core data to disk...
[19:20:06] Done: 150141 -> 43439 (compressed to 28.9 percent)
[19:20:06] ... Done.
[19:20:07] - Shutting down core
[19:20:07]
[19:20:07] Folding@home Core Shutdown: FINISHED_UNIT
[19:20:10] CoreStatus = 64 (100)
[19:20:10] Unit 4 finished with 88 percent of time to deadline remaining.
[19:20:10] Updated performance fraction: 0.853503
[19:20:10] Sending work to server
[19:20:10] Project: 5900 (Run 11, Clone 469, Gen 63)
[19:20:10] - Read packet limit of 540015616... Set to 524286976.
[19:20:10] + Attempting to send results [May 16 19:20:10 UTC]
[19:20:10] - Reading file work/wuresults_04.dat from core
[19:20:10] (Read 43951 bytes from disk)
[19:20:10] Connecting to http://171.64.122.70:8080/
[19:20:13] Posted data.
[19:20:13] Initial: 0000; - Uploaded at ~14 kB/s
[19:20:13] - Averaged speed for that direction ~12 kB/s
[19:20:13] + Results successfully sent
[19:20:13] Thank you for your contribution to Folding@Home.
[19:20:13] + Number of Units Completed: 574
[19:20:17] Trying to send all finished work units
[19:20:17] + No unsent completed units remaining.
[19:20:17] - Preparing to get new work unit...
[19:20:17] + Attempting to get work packet
[19:20:17] - Will indicate memory of 8190 MB
[19:20:17] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 10
[19:20:17] - Connecting to assignment server
[19:20:17] Connecting to http://assign-GPU.stanford.edu:8080/
[19:20:18] Posted data.
[19:20:18] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[19:20:18] + News From Folding@Home: GPU folding beta
[19:20:19] Loaded queue successfully.
[19:20:19] Connecting to http://171.64.65.106:8080/
[19:20:19] Posted data.
[19:20:19] Initial: 0000; + Could not connect to Work Server
[19:20:19] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[19:20:33] + Attempting to get work packet
[19:20:33] - Will indicate memory of 8190 MB
[19:20:33] - Connecting to assignment server
[19:20:33] Connecting to http://assign-GPU.stanford.edu:8080/
[19:20:33] Posted data.
[19:20:33] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[19:20:33] + News From Folding@Home: GPU folding beta
[19:20:33] Loaded queue successfully.
[19:20:33] Connecting to http://171.64.65.106:8080/
[19:20:34] Posted data.
[19:20:34] Initial: 0000; - Receiving payload (expected size: 66921)
[19:20:35] - Downloaded at ~65 kB/s
[19:20:35] - Averaged speed for that direction ~111 kB/s
[19:20:35] + Received work.
[19:20:35] Trying to send all finished work units
[19:20:35] + No unsent completed units remaining.
[19:20:35] + Closed connections
[19:20:35]
[19:20:35] + Processing work unit
[19:20:35] Core required: FahCore_11.exe
[19:20:35] Core found.
[19:20:35] Working on queue slot 05 [May 16 19:20:35 UTC]
[19:20:35] + Working ...
[19:20:35] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[19:20:35]
[19:20:35] *------------------------------*
[19:20:35] Folding@Home GPU Core - Beta
[19:20:35] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[19:20:35]
[19:20:35] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:20:35] Build host: amoeba
[19:20:35] Board Type: Nvidia
[19:20:35] Core :
[19:20:35] Preparing to commence simulation
[19:20:35] - Looking at optimizations...
[19:20:35] - Created dyn
[19:20:35] - Files status OK
[19:20:35] - Expanded 66409 -> 348500 (decompressed 524.7 percent)
[19:20:35] Called DecompressByteArray: compressed_data_size=66409 data_size=348500, decompressed_data_size=348500 diff=0
[19:20:35] - Digital signature verified
[19:20:35]
[19:20:35] Project: 5779 (Run 8, Clone 896, Gen 2)
[19:20:35]
[19:20:36] Assembly optimizations on if available.
[19:20:36] Entering M.D.
[19:20:42] Working on Protein
[19:20:43] Client config found, loading data.
[19:20:43] Starting GUI Server
[19:28:23] Completed 1%
[19:36:07] Completed 2%
[19:43:58] Completed 3%
[19:51:49] Completed 4%
[19:59:33] Completed 5%
[20:07:13] Completed 6%
[20:14:53] Completed 7%
[20:22:32] Completed 8%
[20:30:11] Completed 9%
[20:37:48] Completed 10%
[20:45:21] Completed 11%
[20:52:54] Completed 12%
[21:00:27] Completed 13%
[21:08:00] Completed 14%
[21:15:33] Completed 15%
[21:23:06] Completed 16%
[21:30:39] Completed 17%
[21:38:13] Completed 18%
[21:45:46] Completed 19%
[21:53:19] Completed 20%
[22:00:52] Completed 21%
[22:08:25] Completed 22%
[22:15:58] Completed 23%
[22:23:31] Completed 24%
[22:26:58] Run: exception thrown during GuardedRun
[22:26:58] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[22:26:58] Going to send back what have done -- stepsTotalG=20000000
[22:26:58] Work fraction=0.2445 steps=20000000.
[22:27:02] logfile size=11060 infoLength=11060 edr=0 trr=23
[22:27:02] - Writing 11596 bytes of core data to disk...
[22:27:02] Done: 11084 -> 3992 (compressed to 36.0 percent)
[22:27:02] ... Done.
[22:27:03]
[22:27:03] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:27:06] CoreStatus = 7A (122)
[22:27:06] Sending work to server
[22:27:06] Project: 5779 (Run 8, Clone 896, Gen 2)
[22:27:06] - Read packet limit of 540015616... Set to 524286976.
[22:27:06] + Attempting to send results [May 16 22:27:06 UTC]
[22:27:06] - Reading file work/wuresults_05.dat from core
[22:27:06] (Read 4504 bytes from disk)
[22:27:06] Connecting to http://171.64.65.106:8080/
[22:27:06] Posted data.
[22:27:06] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[22:27:06] - Uploaded at ~10 kB/s
[22:27:06] - Averaged speed for that direction ~12 kB/s
[22:27:06] + Results successfully sent
[22:27:06] Thank you for your contribution to Folding@Home.
[22:27:10] Trying to send all finished work units
[22:27:10] + No unsent completed units remaining.
[22:27:10] - Preparing to get new work unit...
[22:27:10] + Attempting to get work packet
[22:27:10] - Will indicate memory of 8190 MB
[22:27:10] - Connecting to assignment server
[22:27:10] Connecting to http://assign-GPU.stanford.edu:8080/
[22:27:11] Posted data.
[22:27:11] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[22:27:11] + News From Folding@Home: GPU folding beta
[22:27:11] Loaded queue successfully.
[22:27:11] Connecting to http://171.64.65.106:8080/
[22:27:11] Initial: 0000; + Could not connect to Work Server
[22:27:11] - Attempt #1 to get work failed, and no other work to do.
[22:27:25] + Attempting to get work packet
[22:27:25] - Will indicate memory of 8190 MB
[22:27:25] - Connecting to assignment server
[22:27:25] Connecting to http://assign-GPU.stanford.edu:8080/
[22:27:25] Posted data.
[22:27:25] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[22:27:25] + News From Folding@Home: GPU folding beta
[22:27:26] Loaded queue successfully.
[22:27:26] Connecting to http://171.64.65.106:8080/
[22:27:26] Posted data.
[22:27:26] Initial: 0000; - Receiving payload (expected size: 63165)
[22:27:26] Conversation time very short, giving reduced weight in bandwidth avg
[22:27:26] - Downloaded at ~123 kB/s
[22:27:26] - Averaged speed for that direction ~113 kB/s
[22:27:26] + Received work.
[22:27:26] Trying to send all finished work units
[22:27:26] + No unsent completed units remaining.
[22:27:26] + Closed connections
[22:27:31]
[22:27:31] + Processing work unit
[22:27:31] Core required: FahCore_11.exe
[22:27:31] Core found.
[22:27:31] Working on queue slot 06 [May 16 22:27:31 UTC]
[22:27:31] + Working ...
[22:27:31] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[22:27:31]
[22:27:31] *------------------------------*
[22:27:31] Folding@Home GPU Core - Beta
[22:27:31] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[22:27:31]
[22:27:31] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:27:31] Build host: amoeba
[22:27:31] Board Type: Nvidia
[22:27:31] Core :
[22:27:31] Preparing to commence simulation
[22:27:31] - Looking at optimizations...
[22:27:31] - Created dyn
[22:27:31] - Files status OK
[22:27:31] - Expanded 62653 -> 348500 (decompressed 556.2 percent)
[22:27:31] Called DecompressByteArray: compressed_data_size=62653 data_size=348500, decompressed_data_size=348500 diff=0
[22:27:31] - Digital signature verified
[22:27:31]
[22:27:31] Project: 5778 (Run 2, Clone 956, Gen 0)
[22:27:31]
[22:27:31] Assembly optimizations on if available.
[22:27:31] Entering M.D.
[22:27:38] Working on Protein
[22:27:39] Client config found, loading data.
[22:27:39] Starting GUI Server
[22:35:10] Completed 1%
[22:42:43] Completed 2%
[22:46:22] - Autosending finished units... [May 16 22:46:22 UTC]
[22:46:22] Trying to send all finished work units
[22:46:22] + No unsent completed units remaining.
[22:46:22] - Autosend completed
[22:50:17] Completed 3%
[22:57:50] Completed 4%
[23:05:23] Completed 5%
[23:12:57] Completed 6%
[23:20:30] Completed 7%
[23:28:04] Completed 8%
[23:35:37] Completed 9%
[23:43:10] Completed 10%
[23:50:44] Completed 11%
[23:58:17] Completed 12%
[00:05:51] Completed 13%
[00:06:19] Run: exception thrown during GuardedRun
[00:06:19] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[00:06:19] Going to send back what have done -- stepsTotalG=20000000
[00:06:19] Work fraction=0.1306 steps=20000000.
[00:06:23] logfile size=11216 infoLength=11216 edr=0 trr=23
[00:06:23] - Writing 11752 bytes of core data to disk...
[00:06:23] Done: 11240 -> 4063 (compressed to 36.1 percent)
[00:06:23] ... Done.
[00:06:25]
[00:06:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:06:28] CoreStatus = 7A (122)
[00:06:28] Sending work to server
[00:06:28] Project: 5778 (Run 2, Clone 956, Gen 0)
[00:06:28] - Read packet limit of 540015616... Set to 524286976.
[00:06:28] + Attempting to send results [May 17 00:06:28 UTC]
[00:06:28] - Reading file work/wuresults_06.dat from core
[00:06:28] (Read 4575 bytes from disk)
[00:06:28] Connecting to http://171.64.65.106:8080/
[00:06:28] Posted data.
[00:06:28] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[00:06:28] - Uploaded at ~10 kB/s
[00:06:28] - Averaged speed for that direction ~12 kB/s
[00:06:28] + Results successfully sent
[00:06:28] Thank you for your contribution to Folding@Home.
[00:06:33] Trying to send all finished work units
[00:06:33] + No unsent completed units remaining.
[00:06:33] - Preparing to get new work unit...
[00:06:33] + Attempting to get work packet
[00:06:33] - Will indicate memory of 8190 MB
[00:06:33] - Connecting to assignment server
[00:06:33] Connecting to http://assign-GPU.stanford.edu:8080/
[00:06:33] Posted data.
[00:06:33] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:06:33] + News From Folding@Home: GPU folding beta
[00:06:33] Loaded queue successfully.
[00:06:33] Connecting to http://171.64.65.106:8080/
[00:06:34] Posted data.
[00:06:34] Initial: 0000; - Receiving payload (expected size: 63866)
[00:06:34] Conversation time very short, giving reduced weight in bandwidth avg
[00:06:34] - Downloaded at ~124 kB/s
[00:06:34] - Averaged speed for that direction ~114 kB/s
[00:06:34] + Received work.
[00:06:34] Trying to send all finished work units
[00:06:34] + No unsent completed units remaining.
[00:06:34] + Closed connections
[00:06:39]
[00:06:39] + Processing work unit
[00:06:39] Core required: FahCore_11.exe
[00:06:39] Core found.
[00:06:39] Working on queue slot 07 [May 17 00:06:39 UTC]
[00:06:39] + Working ...
[00:06:39] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[00:06:39]
[00:06:39] *------------------------------*
[00:06:39] Folding@Home GPU Core - Beta
[00:06:39] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:06:39]
[00:06:39] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:06:39] Build host: amoeba
[00:06:39] Board Type: Nvidia
[00:06:39] Core :
[00:06:39] Preparing to commence simulation
[00:06:39] - Looking at optimizations...
[00:06:39] - Created dyn
[00:06:39] - Files status OK
[00:06:39] - Expanded 63354 -> 348500 (decompressed 550.0 percent)
[00:06:39] Called DecompressByteArray: compressed_data_size=63354 data_size=348500, decompressed_data_size=348500 diff=0
[00:06:39] - Digital signature verified
[00:06:39]
[00:06:39] Project: 5778 (Run 13, Clone 963, Gen 0)
[00:06:39]
[00:06:39] Assembly optimizations on if available.
[00:06:39] Entering M.D.
[00:06:46] Working on Protein
[00:06:47] Run: exception thrown during GuardedRun
[00:06:47] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[00:06:47] Going to send back what have done -- stepsTotalG=0
[00:06:47] Work fraction=0.0000 steps=0.
[00:06:51] logfile size=0 infoLength=0 edr=0 trr=23
[00:06:51] - Writing 635 bytes of core data to disk...
[00:06:51] Done: 123 -> 124 (compressed to 100.8 percent)
[00:06:51] ... Done.
[00:06:52]
[00:06:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:06:55] CoreStatus = 7A (122)
[00:06:55] Sending work to server
[00:06:55] Project: 5778 (Run 13, Clone 963, Gen 0)
[00:06:55] - Read packet limit of 540015616... Set to 524286976.
[00:06:55] + Attempting to send results [May 17 00:06:55 UTC]
[00:06:55] - Reading file work/wuresults_07.dat from core
[00:06:55] (Read 636 bytes from disk)
[00:06:55] Connecting to http://171.64.65.106:8080/
[00:06:56] Posted data.
[00:06:56] Initial: 0000; - Uploaded at ~1 kB/s
[00:06:56] - Averaged speed for that direction ~10 kB/s
[00:06:56] + Results successfully sent
[00:06:56] Thank you for your contribution to Folding@Home.
[00:07:00] Trying to send all finished work units
[00:07:00] + No unsent completed units remaining.
[00:07:00] - Preparing to get new work unit...
[00:07:00] + Attempting to get work packet
[00:07:00] - Will indicate memory of 8190 MB
[00:07:00] - Connecting to assignment server
[00:07:00] Connecting to http://assign-GPU.stanford.edu:8080/
[00:07:00] Posted data.
[00:07:00] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:07:00] + News From Folding@Home: GPU folding beta
[00:07:00] Loaded queue successfully.
[00:07:00] Connecting to http://171.64.65.106:8080/
[00:07:01] Posted data.
[00:07:01] Initial: 0000; + Could not connect to Work Server
[00:07:01] - Attempt #1 to get work failed, and no other work to do.
[00:07:06] + Attempting to get work packet
[00:07:06] - Will indicate memory of 8190 MB
[00:07:06] - Connecting to assignment server
[00:07:06] Connecting to http://assign-GPU.stanford.edu:8080/
[00:07:06] Posted data.
[00:07:06] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:07:06] + News From Folding@Home: GPU folding beta
[00:07:06] Loaded queue successfully.
[00:07:06] Connecting to http://171.64.65.106:8080/
[00:07:06] Initial: 0000; + Could not connect to Work Server
[00:07:06] - Attempt #2 to get work failed, and no other work to do.
[00:07:27] + Attempting to get work packet
[00:07:27] - Will indicate memory of 8190 MB
[00:07:27] - Connecting to assignment server
[00:07:27] Connecting to http://assign-GPU.stanford.edu:8080/
[00:07:27] Posted data.
[00:07:27] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:07:27] + News From Folding@Home: GPU folding beta
[00:07:27] Loaded queue successfully.
[00:07:27] Connecting to http://171.64.65.106:8080/
[00:07:28] Posted data.
[00:07:28] Initial: 0000; - Receiving payload (expected size: 66787)
[00:07:28] Conversation time very short, giving reduced weight in bandwidth avg
[00:07:28] - Downloaded at ~130 kB/s
[00:07:28] - Averaged speed for that direction ~116 kB/s
[00:07:28] + Received work.
[00:07:28] Trying to send all finished work units
[00:07:28] + No unsent completed units remaining.
[00:07:28] + Closed connections
[00:07:33]
[00:07:33] + Processing work unit
[00:07:33] Core required: FahCore_11.exe
[00:07:33] Core found.
[00:07:33] Working on queue slot 08 [May 17 00:07:33 UTC]
[00:07:33] + Working ...
[00:07:33] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[00:07:33]
[00:07:33] *------------------------------*
[00:07:33] Folding@Home GPU Core - Beta
[00:07:33] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:07:33]
[00:07:33] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:07:33] Build host: amoeba
[00:07:33] Board Type: Nvidia
[00:07:33] Core :
[00:07:33] Preparing to commence simulation
[00:07:33] - Looking at optimizations...
[00:07:33] - Created dyn
[00:07:33] - Files status OK
[00:07:33] - Expanded 66275 -> 348500 (decompressed 525.8 percent)
[00:07:33] Called DecompressByteArray: compressed_data_size=66275 data_size=348500, decompressed_data_size=348500 diff=0
[00:07:33] - Digital signature verified
[00:07:33]
[00:07:33] Project: 5779 (Run 6, Clone 942, Gen 1)
[00:07:33]
[00:07:33] Assembly optimizations on if available.
[00:07:33] Entering M.D.
[00:07:40] Working on Protein
[00:07:41] Client config found, loading data.
[00:07:41] Starting GUI Server
[00:15:22] Completed 1%
[00:23:08] Completed 2%
[00:30:55] Completed 3%
[00:38:37] Completed 4%
[00:46:21] Completed 5%
[00:54:03] Completed 6%
[01:01:45] Completed 7%
[01:09:26] Completed 8%
[01:17:14] Completed 9%
[01:24:57] Completed 10%
[01:32:39] Completed 11%
[01:39:30] Run: exception thrown during GuardedRun
[01:39:30] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[01:39:30] Going to send back what have done -- stepsTotalG=20000000
[01:39:30] Work fraction=0.1189 steps=20000000.
[01:39:34] logfile size=10564 infoLength=10564 edr=0 trr=23
[01:39:34] - Writing 11100 bytes of core data to disk...
[01:39:34] Done: 10588 -> 3895 (compressed to 36.7 percent)
[01:39:34] ... Done.
[01:39:36]
[01:39:36] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:39:40] CoreStatus = 7A (122)
[01:39:40] Sending work to server
[01:39:40] Project: 5779 (Run 6, Clone 942, Gen 1)
[01:39:40] - Read packet limit of 540015616... Set to 524286976.
[01:39:40] + Attempting to send results [May 17 01:39:40 UTC]
[01:39:40] - Reading file work/wuresults_08.dat from core
[01:39:40] (Read 4407 bytes from disk)
[01:39:40] Connecting to http://171.64.65.106:8080/
[01:39:40] Posted data.
[01:39:40] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[01:39:40] - Uploaded at ~10 kB/s
[01:39:40] - Averaged speed for that direction ~10 kB/s
[01:39:40] + Results successfully sent
[01:39:40] Thank you for your contribution to Folding@Home.
[01:39:45] Trying to send all finished work units
[01:39:45] + No unsent completed units remaining.
[01:39:45] - Preparing to get new work unit...
[01:39:45] + Attempting to get work packet
[01:39:45] - Will indicate memory of 8190 MB
[01:39:45] - Connecting to assignment server
[01:39:45] Connecting to http://assign-GPU.stanford.edu:8080/
[01:39:45] Posted data.
[01:39:45] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[01:39:45] + News From Folding@Home: GPU folding beta
[01:39:45] Loaded queue successfully.
[01:39:45] Connecting to http://171.67.108.11:8080/
[01:39:46] Posted data.
[01:39:46] Initial: 0000; - Receiving payload (expected size: 47199)
[01:39:46] Conversation time very short, giving reduced weight in bandwidth avg
[01:39:46] - Downloaded at ~92 kB/s
[01:39:46] - Averaged speed for that direction ~113 kB/s
[01:39:46] + Received work.
[01:39:46] Trying to send all finished work units
[01:39:46] + No unsent completed units remaining.
[01:39:46] + Closed connections
[01:39:51]
[01:39:51] + Processing work unit
[01:39:51] Core required: FahCore_11.exe
[01:39:51] Core found.
[01:39:51] Working on queue slot 09 [May 17 01:39:51 UTC]
[01:39:51] + Working ...
[01:39:51] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[01:39:51]
[01:39:51] *------------------------------*
[01:39:51] Folding@Home GPU Core - Beta
[01:39:51] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:39:51]
[01:39:51] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:39:51] Build host: amoeba
[01:39:51] Board Type: Nvidia
[01:39:51] Core :
[01:39:51] Preparing to commence simulation
[01:39:51] - Looking at optimizations...
[01:39:51] - Created dyn
[01:39:51] - Files status OK
[01:39:51] - Expanded 46687 -> 252912 (decompressed 541.7 percent)
[01:39:51] Called DecompressByteArray: compressed_data_size=46687 data_size=252912, decompressed_data_size=252912 diff=0
[01:39:51] - Digital signature verified
[01:39:51]
[01:39:51] Project: 5766 (Run 2, Clone 403, Gen 542)
[01:39:51]
[01:39:51] Assembly optimizations on if available.
[01:39:51] Entering M.D.
[01:39:57] Working on Protein
[01:39:58] Client config found, loading data.
[01:39:58] Starting GUI Server
[01:42:38] Completed 1%
[01:45:19] Completed 2%
[01:47:59] Completed 3%
[01:50:40] Completed 4%
[01:53:21] Completed 5%
[01:56:02] Completed 6%
[01:58:42] Completed 7%
[02:01:23] Completed 8%
[02:04:04] Completed 9%
[02:06:45] Completed 10%
[02:09:25] Completed 11%
[02:12:06] Completed 12%
[02:14:47] Completed 13%
[02:17:28] Completed 14%
[02:20:09] Completed 15%
[02:22:49] Completed 16%
[02:25:30] Completed 17%
[02:28:11] Completed 18%
[02:30:52] Completed 19%
[02:33:32] Completed 20%
[02:36:13] Completed 21%
[02:38:54] Completed 22%
[02:41:35] Completed 23%
[02:44:15] Completed 24%
[02:46:56] Completed 25%
[02:49:37] Completed 26%
[02:52:18] Completed 27%
[02:54:59] Completed 28%
[02:57:39] Completed 29%
[03:00:20] Completed 30%
[03:03:01] Completed 31%
[03:05:42] Completed 32%
[03:08:23] Completed 33%
[03:11:03] Completed 34%
[03:13:44] Completed 35%
[03:16:25] Completed 36%
[03:19:06] Completed 37%
[03:21:46] Completed 38%
[03:24:27] Completed 39%
[03:27:08] Completed 40%
[03:29:49] Completed 41%
[03:32:30] Completed 42%
[03:35:11] Completed 43%
[03:37:51] Completed 44%
[03:40:32] Completed 45%
[03:43:13] Completed 46%
[03:45:54] Completed 47%
[03:48:34] Completed 48%
[03:51:15] Completed 49%
[03:53:56] Completed 50%
[03:56:37] Completed 51%
[03:59:18] Completed 52%
[04:01:58] Completed 53%
[04:04:39] Completed 54%
[04:07:20] Completed 55%
[04:10:01] Completed 56%
[04:12:41] Completed 57%
[04:15:22] Completed 58%
[04:18:03] Completed 59%
[04:20:44] Completed 60%
[04:23:24] Completed 61%
[04:26:05] Completed 62%
[04:28:46] Completed 63%
[04:31:27] Completed 64%
[04:34:08] Completed 65%
[04:36:48] Completed 66%
[04:39:29] Completed 67%
[04:42:10] Completed 68%
[04:44:51] Completed 69%
[04:46:19] - Autosending finished units... [May 17 04:46:19 UTC]
[04:46:19] Trying to send all finished work units
[04:46:19] + No unsent completed units remaining.
[04:46:19] - Autosend completed
[04:47:31] Completed 70%
[04:50:12] Completed 71%
[04:52:53] Completed 72%
[04:55:34] Completed 73%
[04:58:14] Completed 74%
[05:00:55] Completed 75%
[05:03:36] Completed 76%
[05:06:17] Completed 77%
[05:08:58] Completed 78%
[05:11:38] Completed 79%
[05:14:19] Completed 80%
[05:17:00] Completed 81%
[05:19:41] Completed 82%
[05:22:21] Completed 83%
[05:25:02] Completed 84%
[05:27:43] Completed 85%
[05:30:24] Completed 86%
[05:33:04] Completed 87%
[05:35:45] Completed 88%
[05:38:26] Completed 89%
[05:41:07] Completed 90%
[05:43:47] Completed 91%
[05:46:28] Completed 92%
[05:49:09] Completed 93%
[05:51:50] Completed 94%
[05:54:31] Completed 95%
[05:57:11] Completed 96%
[05:59:52] Completed 97%
[06:02:33] Completed 98%
[06:05:14] Completed 99%
[06:07:54] Completed 100%
[06:07:56] Successful run
[06:07:56] DynamicWrapper: Finished Work Unit: sleep=10000
[06:08:06] Reserved 75892 bytes for xtc file; Cosm status=0
[06:08:06] Allocated 75892 bytes for xtc file
[06:08:06] - Reading up to 75892 from "work/wudata_09.xtc": Read 75892
[06:08:06] Read 75892 bytes from xtc file; available packet space=786354572
[06:08:06] xtc file hash check passed.
[06:08:06] Reserved 15168 15168 786354572 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[06:08:06] Allocated 15168 bytes for arc file
[06:08:06] - Reading up to 15168 from "work/wudata_09.trr": Read 15168
[06:08:06] Read 15168 bytes from arc file; available packet space=786339404
[06:08:06] trr file hash check passed.
[06:08:06] Allocated 560 bytes for edr file
[06:08:06] Read bedfile
[06:08:06] edr file hash check passed.
[06:08:06] Allocated 11195 bytes for logfile
[06:08:06] Read logfile
[06:08:06] GuardedRun: success in DynamicWrapper
[06:08:06] GuardedRun: done
[06:08:06] Run: GuardedRun completed.
[06:08:08] - Writing 103327 bytes of core data to disk...
[06:08:08] Done: 102815 -> 95737 (compressed to 93.1 percent)
[06:08:08] ... Done.
[06:08:08] - Shutting down core
[06:08:08]
[06:08:08] Folding@home Core Shutdown: FINISHED_UNIT
[06:08:11] CoreStatus = 64 (100)
[06:08:11] Unit 9 finished with 94 percent of time to deadline remaining.
[06:08:11] Updated performance fraction: 0.870376
[06:08:11] Sending work to server
[06:08:11] Project: 5766 (Run 2, Clone 403, Gen 542)
[06:08:11] - Read packet limit of 540015616... Set to 524286976.
[06:08:11] + Attempting to send results [May 17 06:08:11 UTC]
[06:08:11] - Reading file work/wuresults_09.dat from core
[06:08:11] (Read 96249 bytes from disk)
[06:08:11] Connecting to http://171.67.108.11:8080/
[06:08:13] Posted data.
[06:08:13] Initial: 0000; - Uploaded at ~31 kB/s
[06:08:14] - Averaged speed for that direction ~14 kB/s
[06:08:14] + Results successfully sent
[06:08:14] Thank you for your contribution to Folding@Home.
[06:08:14] + Number of Units Completed: 575
[06:08:18] Trying to send all finished work units
[06:08:18] + No unsent completed units remaining.
[06:08:18] - Preparing to get new work unit...
[06:08:18] + Attempting to get work packet
[06:08:18] - Will indicate memory of 8190 MB
[06:08:18] - Connecting to assignment server
[06:08:18] Connecting to http://assign-GPU.stanford.edu:8080/
[06:08:18] Posted data.
[06:08:18] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[06:08:18] + News From Folding@Home: GPU folding beta
[06:08:18] Loaded queue successfully.
[06:08:18] Connecting to http://171.64.65.106:8080/
[06:08:19] Posted data.
[06:08:19] Initial: 0000; - Receiving payload (expected size: 63966)
[06:08:19] Conversation time very short, giving reduced weight in bandwidth avg
[06:08:19] - Downloaded at ~124 kB/s
[06:08:19] - Averaged speed for that direction ~114 kB/s
[06:08:19] + Received work.
[06:08:19] Trying to send all finished work units
[06:08:19] + No unsent completed units remaining.
[06:08:19] + Closed connections
[06:08:19]
[06:08:19] + Processing work unit
[06:08:19] Core required: FahCore_11.exe
[06:08:19] Core found.
[06:08:19] Working on queue slot 00 [May 17 06:08:19 UTC]
[06:08:19] + Working ...
[06:08:19] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[06:08:19]
[06:08:19] *------------------------------*
[06:08:19] Folding@Home GPU Core - Beta
[06:08:19] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:08:19]
[06:08:19] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:08:19] Build host: amoeba
[06:08:19] Board Type: Nvidia
[06:08:19] Core :
[06:08:19] Preparing to commence simulation
[06:08:19] - Looking at optimizations...
[06:08:19] - Created dyn
[06:08:19] - Files status OK
[06:08:19] - Expanded 63454 -> 348500 (decompressed 549.2 percent)
[06:08:19] Called DecompressByteArray: compressed_data_size=63454 data_size=348500, decompressed_data_size=348500 diff=0
[06:08:19] - Digital signature verified
[06:08:19]
[06:08:19] Project: 5780 (Run 11, Clone 873, Gen 0)
[06:08:19]
[06:08:20] Assembly optimizations on if available.
[06:08:20] Entering M.D.
[06:08:26] Working on Protein
[06:08:27] Client config found, loading data.
[06:08:27] Starting GUI Server
[06:15:58] Completed 1%
[06:23:31] Completed 2%
[06:31:04] Completed 3%
[06:38:36] Completed 4%
[06:46:09] Completed 5%
[06:53:42] Completed 6%
[07:01:15] Completed 7%
[07:08:48] Completed 8%
[07:16:21] Completed 9%
[07:23:53] Completed 10%
[07:31:26] Completed 11%
[07:38:59] Completed 12%
[07:46:32] Completed 13%
[07:54:05] Completed 14%
[08:01:38] Completed 15%
[08:09:10] Completed 16%
[08:16:43] Completed 17%
[08:24:19] Completed 18%
[08:32:01] Completed 19%
[08:39:41] Completed 20%
[08:47:20] Completed 21%
[08:54:58] Completed 22%
[09:02:37] Completed 23%
[09:10:16] Completed 24%
[09:17:53] Completed 25%
[09:25:30] Completed 26%
[09:33:05] Completed 27%
[09:40:38] Completed 28%
[09:48:11] Completed 29%
[09:55:44] Completed 30%
[10:03:16] Completed 31%
[10:10:49] Completed 32%
[10:18:22] Completed 33%
[10:25:55] Completed 34%
[10:33:28] Completed 35%
[10:41:00] Completed 36%
[10:46:16] - Autosending finished units... [May 17 10:46:16 UTC]
[10:46:16] Trying to send all finished work units
[10:46:16] + No unsent completed units remaining.
[10:46:16] - Autosend completed
[10:48:33] Completed 37%
[10:56:06] Completed 38%
[11:03:39] Completed 39%
[11:11:12] Completed 40%
[11:18:44] Completed 41%
[11:26:17] Completed 42%
[11:33:50] Completed 43%
[11:41:23] Completed 44%
[11:48:56] Completed 45%
[11:56:29] Completed 46%
[12:04:01] Completed 47%
[12:11:34] Completed 48%
[12:19:07] Completed 49%
[12:26:40] Completed 50%
[12:34:13] Completed 51%
[12:41:45] Completed 52%
[12:49:18] Completed 53%
[12:56:51] Completed 54%
[13:04:24] Completed 55%
[13:11:57] Completed 56%
[13:19:29] Completed 57%
[13:27:02] Completed 58%
[13:34:35] Completed 59%
[13:42:08] Completed 60%
[13:49:41] Completed 61%
[13:57:13] Completed 62%
[14:04:46] Completed 63%
[14:12:19] Completed 64%
[14:19:52] Completed 65%
[14:27:25] Completed 66%
[14:34:58] Completed 67%
[14:42:31] Completed 68%
[14:49:30] Run: exception thrown during GuardedRun
[14:49:30] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[14:49:30] Going to send back what have done -- stepsTotalG=20000000
[14:49:30] Work fraction=0.6892 steps=20000000.
[14:49:34] logfile size=10844 infoLength=10844 edr=0 trr=23
[14:49:34] - Writing 11380 bytes of core data to disk...
[14:49:34] Done: 10868 -> 3999 (compressed to 36.7 percent)
[14:49:34] ... Done.
[14:49:35]
[14:49:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:49:37] CoreStatus = 7A (122)
[14:49:37] Sending work to server
[14:49:37] Project: 5780 (Run 11, Clone 873, Gen 0)
[14:49:37] - Read packet limit of 540015616... Set to 524286976.
[14:49:37] + Attempting to send results [May 17 14:49:37 UTC]
[14:49:37] - Reading file work/wuresults_00.dat from core
[14:49:37] (Read 4511 bytes from disk)
[14:49:37] Connecting to http://171.64.65.106:8080/
[14:49:38] Posted data.
[14:49:38] Initial: 0000; - Uploaded at ~5 kB/s
[14:49:38] - Averaged speed for that direction ~12 kB/s
[14:49:38] + Results successfully sent
[14:49:38] Thank you for your contribution to Folding@Home.
[14:49:42] Trying to send all finished work units
[14:49:42] + No unsent completed units remaining.
[14:49:42] - Preparing to get new work unit...
[14:49:42] + Attempting to get work packet
[14:49:42] - Will indicate memory of 8190 MB
[14:49:42] - Connecting to assignment server
[14:49:42] Connecting to http://assign-GPU.stanford.edu:8080/
[14:49:42] Posted data.
[14:49:42] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[14:49:42] + News From Folding@Home: GPU folding beta
[14:49:42] Loaded queue successfully.
[14:49:42] Connecting to http://171.67.108.11:8080/
[14:49:42] Initial: 0000; - Receiving payload (expected size: 99228)
[14:49:43] - Downloaded at ~96 kB/s
[14:49:43] - Averaged speed for that direction ~111 kB/s
[14:49:43] + Received work.
[14:49:43] Trying to send all finished work units
[14:49:43] + No unsent completed units remaining.
[14:49:43] + Closed connections
[14:49:48]
[14:49:48] + Processing work unit
[14:49:48] Core required: FahCore_11.exe
[14:49:48] Core found.
[14:49:48] Working on queue slot 01 [May 17 14:49:48 UTC]
[14:49:48] + Working ...
[14:49:48] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -nocpulock -checkpoint 20 -verbose -lifeline 3284 -version 623'
[14:49:48]
[14:49:48] *------------------------------*
[14:49:48] Folding@Home GPU Core - Beta
[14:49:48] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:49:48]
[14:49:48] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:49:48] Build host: amoeba
[14:49:48] Board Type: Nvidia
[14:49:48] Core :
[14:49:48] Preparing to commence simulation
[14:49:48] - Looking at optimizations...
[14:49:48] - Created dyn
[14:49:48] - Files status OK
[14:49:48] - Expanded 98716 -> 492276 (decompressed 498.6 percent)
[14:49:48] Called DecompressByteArray: compressed_data_size=98716 data_size=492276, decompressed_data_size=492276 diff=0
[14:49:48] - Digital signature verified
[14:49:48]
[14:49:48] Project: 5756 (Run 5, Clone 256, Gen 270)
[14:49:48]
[14:49:48] Assembly optimizations on if available.
[14:49:48] Entering M.D.
[14:49:54] Working on Protein
[14:49:57] Client config found, loading data.
[14:49:57] Starting GUI Server
[14:57:08] Completed 1%
[15:04:22] Completed 2%
[15:11:34] Completed 3%
[15:18:48] Completed 4%
[15:25:59] Completed 5%
[15:33:11] Completed 6%
[15:40:22] Completed 7%
[15:46:55] ***** Got a SIGTERM signal (2)
[15:46:55] Killing all core threads
