External Blu-Ray Players
bob4933
Do you need a writer or just a player?
not familiar with external writers, but I dont see anything inherently wrong with that model you chose.
habbajabba
Oregon
I use a cheapo external writer that came with two usb cable ends for power. I swapped the dual cable out for a proper usb3 one connected to a 4port anker with ext power. Works perfectly. Highly recommend the external m-disc burners. That asus just about oughta do it. The super slim ones like I have are too flimsy. That one is built like a tank but does not burn m-discs unfortunately. Flawless with blu-rays though.
Theocnoob
Near Toronto Canada
Do you NEED an optical drive? I haven't used mine since like 2011...
Windows can be downloaded to USB (or even bought on USB)
Movies are on Netflix and Kodi etc
TV shows are on Hulu
Games are all online (Steam, Origin, Uplay, etc etc)
Drivers can be (and should be gotten) online. This is better as you will get a more recent version
There is literally no reason to use an optical drive unless you need to burn discs for someone, in which case I think that person should ask themselves why they're still using an archaic and out-dated technology. :p
JM2C
Having said that, go ahead and get a cheap little USB external optical drive if you want. They're cheap enough.
Killahurtz
"There is literally no reason to use an optical drive unless you need to burn discs for someone".....hahahahaha
JrClocker
AKA: JrMiyagi
I bought an internal bluray writer, and put it in an external 5.25" USB enclosure...out of the case, and only power it up when I need it.
MikeJ
MikeJ
Need it to burn my dvds and blu-rays and my music cd collection so i can put them on a NAS
