- Apr 3, 2015
- Planet Earth
What's Chillin' in Extreme Cooling?
(har, I kill myself)
So, have been working with water for a bit now on The Bianch and still have Father Time to finish...
(see links in sig)
My original idea was to equip Father Time with external ports for a chiller, which will eventually happen.
But as I "practice" on The Bianch, I noticed something that should let me experiment with an external cooling approach.
So I am looking for feedback/advice on approaches for using an external res/et. al to achieve sub-ambient temps.
From the fishtank to a submersible solution.
Here is what I am working with on The Bianch...
This gives a good idea of the current loop set-up
This shows the two expansion ports. I use the one on the left to fill and is the out. The in is the one down by the pump. Right?
EDIT: OK, durr. Its a radiator I need to submerse, not a res! silly dunderhead!
So my idea is to get something like:
http://www.performance-pcs.com/froz...tion-reservoir-black-acetal.html#!prettyPhoto
Something that you can submerse in whatever medium I choose: ice water, etc. In whatever tub/tank, bucket.
Is this the standard approach, kinda?
Or when I hear people talk about floating something in their tank are we doing an active cooling of the actual coolant and the tank/loop is open?
Or are we doing a passive, conductive process, where we keep our loops closed and use the said before-mentioned approach?
Cause I did see a submersible pump specific to computer water cooling??
I also realize I will need to introduce another pump in the loop.
The shown res has a mount for pump on back, but can you submerse the entire thing with pump?
Or just put pump in-line somewhere on external res out?
Also I had some question involving coolant.
Up to this point I am using the manufacture's coolant, the good stuff, and its spendy as we all know.
I haven't really looked yet into DIY coolants, yet I know many people use them.
Any pointers here. I kinda looked for a thread on DIY coolant, but it eluded me.
So that's about it for now. I know what I want to accomplish,
but not necessarily all the wisdom to do it.
That were you all come in
Thanks,
Cheers
(see links in sig)
Cheers
