extreem underclocker
Gonzi
Sacramento CA
Hello everyone just wanted to tell you I am succesfully underclocked at [email protected] with my new xp1800.
Yea isnt that great! HA HA
Anyway my chip wont run at [email protected] and to top that off I downloaded WCUPID and it sais it is a Athlon MP .
Question if my chip is improperly unlocked would this problem arise? My unlock job was done under a microscope with 0ohm resistors, looks great so whats the problem.
Revx
IL
it could be your just got some other bridges in the process, because i know there is a bridge you can connect on the athlon xps that make them think they are mps, i donno, maybe cleaning off the unlocking job and trying again would help
elysium
NORWAY
The xp 1800+ runs at 1,53GHz
Congrats on the UNDERclocking, though it seems you're in the wrong forum. Try underclockers.com instead, cause this is OVERclockers.com's forum.Glad to help you out.
Hehe
Ely
David
Forums Super Moderator
AthlonMPs and XPs are very similar - they both use the palamino core. Its nothing to worry about IMHO.
