F@H core won't shutdown after finishing WU
Ducker
The Dark Side of the Moon
Just like it says in the subject line. F@H seems to run just fine until after it has finished folding the last frame. Then it says it's writing core data to the disk & says "Shutting down core" and just sits there. Unfourtainately for hours, when I was asleep and unable to check it.
I tried deleting the FAHCore_78 & using a newly downloaded one, didn't help. Tried downloading a new FAH4.00 client, still does the same thing, runs to the end & hangs at "Shutting down core". Arrrrrghhhhh!!! This is killing my stats!! So far I have managed to lose 2 days folding time on my fastest rig & delete 2 wu's. Any help would be greatly appreciated! Below is a copy of what's on my screen.
Note: Please read the license agreement (FAH4.00-Console-Pre1.exe -license). Fur
ther
use of this software requires that you have read and accepted this agreement.
No directory settings found in registry. Using current directory...
--- Opening Log file [January 1 19:39:31]
# Windows Console Edition #####################################################
Folding@home Client Version 4.00-Prerelease1
http://folding.stanford.edu
Arguments: -service -forceSSE -advmethods
Warning:
By using the -forceSSE flag, you are overriding program
safeguards that monitor the stability of SSE
instructions on your system. If you did not intend
to do this, please restart the program without
-forceSSE. If work units are not completing fully,
then please discontinue use of the flag.
[19:39:31] - Ask before connecting: No
[19:39:31] - User name: Ducker (Team 32)
[19:39:31] - User ID = 147791C41201BE2C
[19:39:31] - Machine ID: 1
[19:39:31]
[19:39:31] Loaded queue successfully.
[19:39:31] + Benchmarking ...
[19:39:34]
[19:39:34] + Processing work unit
[19:39:34] Core required: FahCore_78.exe
[19:39:34] Core found.
[19:39:34] Working on Unit 06 [January 1 19:39:34]
[19:39:34] + Working ...
[19:39:34]
[19:39:34] *------------------------------*
[19:39:34] Folding@home Gromacs Core
[19:39:34] Version 1.54 (November 26, 2003)
[19:39:34]
[19:39:34] Preparing to commence simulation
[19:39:34] - Ensuring status. Please wait.
[19:39:51] - Assembly optimizations manually forced on.
[19:39:51] - Not checking prior termination.
[19:39:52] - Expanded 511019 -> 2524925 (decompressed 494.0 percent)
[19:39:52]
[19:39:52] Project: 920 (Run 35, Clone 64, Gen 2)
[19:39:52]
[19:39:53] Assembly optimizations on if available.
[19:39:53] Entering M.D.
[19:40:15] (Starting from checkpoint)
[19:40:15] Protein: p920_vpf910
[19:40:15]
[19:40:15] Writing local files
[19:40:18] Completed 242500 out of 250000 steps (97)
[19:40:19] Extra SSE boost OK.
[19:48:25] Writing local files
[19:48:27] Completed 245000 out of 250000 steps (98)
[19:56:31] Writing local files
[19:56:33] Completed 247500 out of 250000 steps (99)
[20:04:38] Writing local files
[20:04:40] Completed 250000 out of 250000 steps (100)
[20:04:42] Writing final coordinates.
[20:04:42] Past main M.D. loop
[20:05:42]
[20:05:42] Finished Work Unit:
[20:05:42] - Reading up to 422856 from "work/wudata_06.arc": Read 422856
[20:05:42] - Reading up to 376484 from "work/wudata_06.xtc": Read 376484
[20:05:42] goefile size: 0
[20:05:42] logfile size: 74891
[20:05:42] Leaving Run
[20:05:43] - Writing 881679 bytes of core data to disk...
[20:05:43] ... Done.
[20:05:43] - Shutting down core
I noticed you're using the prerelease 1 version. Try downloading the final version on Stanford's site, and run it on a different directory.
I would post a thread on the official folding forum.
