F@H on Ubuntu 22.04 How To
Question: Why make a bootable USB drive for Linux or any other OS, what's wrong with DVD's? And if the .iso is too big for a 4.7GB DVD then just get a DL 8.5GB DVD to burn to like what I'm doing right now for 24.04 LTS :). Just make sure your DVD drive can read and wright to a DL disk.
I honestly thought this was a necro post from 10 years ago.:chair::giggle:
Im sure you can, but the first reason that jumps into my head, is speed. Optical drives are slow.
Also, everyone has USB ports... everyone does not an optical drive in 2024 (I haven't had one in probably a decade).
Might I add: it's just plain simpler to make a bootable USB drive. Plus, DL DVDs? Personally I ran out of 'em a few years ago and am not buying anymore. I know most of youse here are mainly Windows users, so Rufus for making a bootable USB would be an option. I personally like Ventoy, makes a bootable USB drive that you can just drop & drag .iso file to and from like it was part of your file system. Ventoy has a DL for Linux, Windows and to make a livecd.
Great write-up. Thank you for spending the time to put it all together. Personally, I just install the f@h client on the workers. I use HFM to monitor/control the folding and clusterSSH to manage the boxes themselves. Funny thing is, I only discovered clusterSSH last year after getting tired of having to SSH into 9 different boxes to run updates and peek in on the systems. Again, thanks a TON for the guide. Should be helpful for a great many people :)
I just got Ubuntu and Fedora dual boot/linux box happy on a bunch of random laptops and PCs (what can I say—playing with LinkedIn learning on all the Comptia lessons for the fun of it 😅)
I’m gonna tweak my work rigs with your method… For now I just have it installed as an app and not FAHclient. I mean it fired right up, but sure feels different from many many years ago running it out of terminal. I know Linux is supposed to run FAH a little faster, but doesn’t feel quite any different from Windows.
I have the latest LTS with Ubuntu 24.04… I’ll give it a try with that just to play around. You’d think 24 would work just as well/compatible with 22… but we’ll see!
I hate search engines, I'm trying to see if I can use Norton Ghost 15 to create a linux 24.04 boot usb drive using the .iso file, but all I get is how to make a Ghost usb drive :bang head:bang head
Now if only I can get it to work, not much documentation on what to do. Trial and error I guess :)
I did find out that 24.04 has Nvidia drivers 535 and 550 in it.
One thing I hate about download sites for software like Rufus and the like is they have so many download links that have nothing to do with what your looking to download. Anyway I got Rufus 4.6 and will try it out with the usb drive I made.
Thank you for the detailed process. I'm about to build a dedicated server board folding machine and hoping this works for me. I downloaded Ubuntu 22.04.5 iso (if that makes any difference) and have it installed on usb. I'll be trying the no-machine as well.
Does anyone know exactly why Linux is better at folding vs Windows? One would think after all these years someone would have figured out a solution for Windows. (Edit) : Browsing the 'net this afternoon I came across someone's post on this subject from a couple of years ago that peaked my interest. In a nutshell they offered up this theory...most users of Linux for Folding are in fact using their machines strictly for Folding whereas those Folding on Windows machines are more likely to be using said machines for other purposes as well. That could easily explain the performance numbers difference between the two OS's. Many have reported the actual differences they experienced between the two in PPD were 3% or less...that's perhaps a failed WU or margin of error territory to me. Makes me want to try a Win 10 OS that has been properly debloated and test.
We've seen significant increases in ppd with multiple cards. It has to do with the scheduler from what I remember. I don't remember exact numbers from our tests when we were setting things up, but I think we saw something like a 1-2mppd increase on dual 4070s vs windows. It's not huge alone, but when you factor in supporting hardware, it can all add up. Our highest ppd on a single card 4070 super was on @KeeperOfTheButch 's gaming rig that he built last year, running windows 11, pcie 5.0, etc. something like 16-18mppd on good wus. But we never ran that machine on Linux.
We are on average getting around 15mppd per 4070ti on our dell 7920 quad card setup. We have a 3900x system on Linux that does a like 16mppd on a ti in the main slot, and 13mppd on 4070 super in secondary slot. Iirc, a 4070 super on windows in my 2700x system on windows did around 12mppd in main slot. I know this doesn't really give you apples to apples, but this is what I can remember. I'd have to check my data for exact differences.
I think there's typically around 10-15% gain, maybe more on multiple cards.
