F@H on Ubuntu 22.04 How To
Attempting to install Linux atm. How can I change the resolution so I can see/access the "continue" tab at the bottom of the screen? Windows keys or right click won't work and my monitor buttons offer no solution.
Nvm...I managed with tab and arrow. What is Python and do I really need it? How do I open the terminal?
Have you turned off the monitor then back on? Every monitor I have used/use goes through a auto adjust when powered on.
Also when using a terminal it will save the commands you type in. If you use the arrow keys you can go through all of the commands you typed in the past so you do not have to repeatedly type them in. You still need your password for Sudo commands.
