- Oct 22, 2001
- Buffalo, NY
how do I add color to my score?
Can you post up your code to turn your WUs yellow like that?
Christoph said:*This is mainly an excuse to link to something in the folding forum from the seti forum. I don't plan on defecting.![]()
print "Work Units:[co lor=yellow]$wus". "[/color]\n";
print "[CO LOR=Orange][SI ZE=1][FO NT=Courier New]Orange Size 1 Courier New[/FONT][/SIZE][/COLOR]";
####################################[b][/b]###########################################
#color_string:
#This function returns its third argument (a string) with color tags, as
#specified by its other parameters.
#Usage: color_string($rgb_i, $rgb_f, $string, $err, $pds, $fun)
#$rgb_i : hex triplet (eg "ff00ff") indicating the color to start with
#$rgb_f : hex triplet indicating the color to stop with
#$string : the string to add color tags to
#All arguments below are optional, but you can't use one without using the ones
#before it. eg you need to specify $err and $pds in order to specify $fun.
#$err : 0-255 - add/subtract random fluctuations between 0 and $err to each
# color. The colors will always be valid, even if $err is large.
#$periods : how many times to cycle from $rgb_i to $rgb_f
#$fun : specify the function used to move between $rgb_i and $rgb_f
#Examples of valid usage:
#$pi = atan2(1,1)*4; #standard definition
#$str = color_string("ff00ff", "ffff00", "Like, wow.");
#$str = color_string("ff00ff", "ffff00", "Like, wow.", 15);
#$str = color_string("ff00ff", "ffff00", "Like, wow.", 15, 2);
#$str = color_string("ff00ff", "ffff00", "Like, wow.", 15, 2,
# sub {my $x = shift; return abs(sin($x*$pi))} );
###########################################[b][/b]####################################
sub color_string
$start_rgb = shift;
$end_rgb = shift;
$string = shift;
#optional args below
$error = shift;
$error = 0 if (! defined $error);
$periods = shift;
$periods = 1 if (! defined $periods);
$fun = shift;
$fun = sub {my $x = shift; return ((255*$x % 256)/255);} if (!defined $fun);
#ugly bug if this isn't declared my
my $color_str;
$str_len = length $string;
$i=0;
foreach $char (split //, $string) {
$fstr_color=color_grad($start_rgb,$end_rgb,$s[b][/b]tr_len,$i++,$error,$periods,$fun);
#vb3 seems to treat individually colored spaces an non-printable
if ($char eq " ") {
$color_str .= "\[color\=\#$invisible\].\[/color\]";
} else {
$color_str .= "\[color\=\#$fstr_color\]$char\[/color\]";
#print "COLOR STRING: returning $color_str\n";
return $color_str;
##########################################[b][/b]#####################################
#color_grad_fun:
#This function returns a single hex triplet based on the parameters passed to
#it.
#Usage: color_grad_fun($rgb_i, $rgb_f, $curr, $err, $pds, $fun)
#$curr : a number between 0 and 1 indicating how far through the gradient
# the color is.
# eg you need to specify $err and $pds in order to specify $fun.
# Default: 0
# Default: 1
# Default: constant increase
sub color_grad_fun
my $start_rgb = shift; #"ff00ff"
my $end_rgb = shift; #"00ff00"
my $curr_step = shift; #floating pt number between 0 and 1. inclusive
#OPTIONAL ARG: error is random variation, in decimal shades
my $error = shift;
#OPTIONAL ARG: how many times to cycle through the above function
my $periods = shift;
#OPTIONAL ARG: function with a period of 1 and a range 0-1 to determine color distribution
my $fun = shift;
#This function has the same behavior as the previous implementation.
$fun = sub {my $x = shift; return ((255*$x % 255)/255);} if (!defined $fun);
$error /= 255;
for $curr (0,1,2) {
$min = hex(substr($start_rgb,$curr*2,2)) / 255;
$max = hex(substr($end_rgb,$curr*2,2)) / 255;
$range = $max - $min;
$funval = &$fun($curr_step*$periods);
#print "max is $max, min is $min, range is $range, step is $curr_step,";
$color[$curr] = ($min + $range*$funval);
if ($error == 0) {
$my_error = 0;
} else {
$my_error = (rand 2*$error) - $error;
while (($color[$curr]+$my_error) < 0 || ($color[$curr]+$my_error) > 1) {
$my_error = ((rand 2*$error) - $error);
#at this point, $my
#print "using error of $my_error, max is $error\n";
#$norml = $color[$curr]*255;
#print "normal color is $norml, ";
$color[$curr] += $my_error;
$color[$curr] *= 255;
#$color[$curr] = sprintf("%.0f",)
#print "color is $color[$curr]\n";
return sprintf("%02x%02x%02x",$color[0],$color[1],$color[2]);
#########################################[b][/b]######################################
#color_grad:
#it. This function is just a wrapper for color_grad_fun. Either can be used.
#Usage: color_grad($rgb_i, $rgb_f, $step_f, $step_c, $err, $pds, $fun)
#$step_f : how many total steps in the gradient (ie step_final)
#$step_c : the number of the current step; if this is half of step_f, the color
# returned will be halfway between rgb_i and rgb_f
sub color_grad
$last_step = shift; #"36"
$curr_step = shift; #"12"
#error is random variation, in decimal shades
$error = shift;
$periods = shift;
$fun = shift;
return color_grad_fun($start_rgb,$end_rgb,$curr_step/$last_step,$error,$periods,$fun);
JerMe said:I'm no programmer...
Christoph said:You lie!
$file_pic = 'C:\\mksig\\dnacolor.txt';
open(INFO, $file_pic);
@lines = <INFO>;
chop(@lines);
close(INFO);
