crimedog said:
I don't want it to auto load on startup for a couple of reasons.
I like to see how it's progressing, if it has any errors, etc.
I like to use EMIII to monitor my FAH4.0 client. But if you don' t want to, you can make a shortcut to your desktop to the fahlog and unitinfo files. You don't need to shut the console down to access these files and they will tell you if you have any errors and the current progress.
When I'm doing certain things, like games or benchmarks or whatever, I like to be able to turn it off easily.
F@H runs totally in the background and has the lowest priority of all programs. If you need to use your cpu(playing games, editing photos, internet browsing) it will back off and allow you to have the cpu power you need without interference.
Here is an article showing the impact of F@H on other programs. They ran benchmarks while folding and showed virtually no change in comparison with F@H not running. I never turn off F@H. I play a lot of games that are fairly cpu intensive, and have had no noticable slow down in my gaming at all. It does however, slow down my folding speed because it backs off so you can play.
*Edit* you can turn off F@H easily by going to the start button and running services.msc on winXP or from the task manager on win98
Plus the idea of a program that sneakily starts up and uses your cpu bothers me.
It's likely you run virus protection software and maybe a firewall program. Do you have MSN Messenger running? Take a look at your task manager and the listing of services that are running. Do you know what they are and what they are doing? I don't. At least with F@H you know what it's doing. It's doing calculations that are going to help find a cure for many terrible diseases. If you have questions about security with F@H, check out
this link at the Stanford website.
If you really don't want to have F@H run at startup, that's great.
I just wanted you to give you some more info to help you make your decision. Most of us here have F@H running as a service at startup, but even if you don't, at least you are folding for Team 32.
Keep folding strong.
