- Dec 17, 2000
- Woodcote, UK
Ok, I finally sat down to do the voltage mod, after much umming and ahhing. I spent ages trying to get one end of the resistor soldered on, and I succeeded after about 10mins, trying not to get the soldering iron tip too close to the smd resistors on the mobo. As soon as I'd done this, I bent the other leg of the resistor round to solder that, and pulled the other one off the mobo again! Agghh, that took me ages!! Plus, when I pulled it away, I could swear the smd resistor was about half the size it was - it's definitely smaller than the one above it, and I guess they ought to be the same size! At that point I said screw it, I've just melted a resistor on my £130 mobo, if I'm really lucky it'll still work but I'm not going near it with that soldering iron again.
It does still work perfectly, which has given me some confidence in the toughness of the resistors - despite my f***-up, they still work. I want to try the mod again, but has anyone got any suggestions to make the legs stick? I've put a small blob of solder on each leg, and I'm holding it in place while i heat it up with the iron (0.5mm tip). Do i need a heat sink for the 24k resistor while i'm soldering, like a piece of wire wrapped around it, tied to a heatsink? Anyone found an easy way to hold the legs in place while soldering? I really need those extra volts for the gig, any tips however irrelevent they may seem would be appreciated, thanks ;-)
