Failing to OC my iGPU :(
GlassWizzard
Hi, I have an i7 4770K, I'm trying to overclock my iGPU using Intel Extreme Tuning Utility but the igpu never goes above 600mhz. I don't know what I'm doing wrong :/
Any help would be appreciated.
Thanks
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Sooooooooooooooooooooo, did it work from within the BIOS or.............? :)
Riddle me this... why are you trying to overclock your iGPU when you have a discrete GPU which, unless you set it otherwise, disables the iGPU?
Do you have drivers installed for the iGPU?
G
GlassWizzard
I want to experiment with my iGPU and get the most out of it, for recording video and streaming. I know I can use the CPU or the GPU but I want to know exactly what my iGPU is capable of. If possible, I would prefer to use it instead of my CPU or GPU for recording/streaming, but as things stand right now, it's just a bit too underpowered.
I don't quite know how to do it from the BIOS. But I will have a go and get back to you.
Vishera
I'm sorry if this offends you, but you have a 1080 and you're opting to use the iGPU?!:bang head
Nebulous
Señor Senior, Senior
The Empire State
Don't quote me on this, but me thinks the iGPU is locked. It's imbedded in the CPU. It will NOT overclock. I tried with mine and I got nothing.
You have a 1080. Don't bother with the iGPU.
EarthDog
Buckeyes!
You should be able to overclock the iGPU. Many boards (perhaps not all) have these options in the BIOS or their mobo's Windows based software.
I would also just record on the 1080 and play on it. Chances are dude is running at 1080 or 2560x1440 which will allow recording and Ultra settings.
We went over that and he answered it before you posted and aksed again, lol... ;)
Nebulous
The Empire State
My board doesn't have that option. Even with the Intel HD Graphics Control Panel software.:confused: Probably the high end boards do ( ie; Asus'). ;)
Nebulous
The Empire State
G
GlassWizzard
Guys, I've been looking into this, and I'm still stuck. I can't find a guide for overclocking the HD4600, neither using IXTU nor the bios. I just don't know what settings to look for/use. I'm guessing there is only a voltage and ratio setting I need to play with?
