Hi all new to the forums. I am currently planning a new build and have already purchased 2 ASUS R9 290 Direct CU II OC and a EVGA Supernova 1200 P2 power supply with red individually sleeved modular cables.
I am planning on the following: ASUS Maximus VII Formula, 4790K, Corsair 760T case (white) and probably either 32 GB G.Skill 2400 MHz Trident if not Corsair Platinum's. Also 2 - 250 GB Samsung 840 Evos.
I have used an XSPC kit on my current rig but, I want to do a custom loop.
Now the MB has a Cross Chill cooler already mounted on the MOSFET using your supplied G1/4 fittings. What I want for now is to cool that, and the CPU. I really hate to add blocks to the GPU's right and void the warranty, but I may have to. Any way if. you guys could come up with a good rad, fans pumps, res. fill/drain system and all else I would appreciate it. I do realize that if I do have to cool the GPU I would probably need an extra loop just for that.
Thanks in advance!
Thanks in advance!
