- Oct 10, 2012
- Secret lair
Ok should be getting my parts on a 3 day shipping six days later, tomorrow.
Anyway, I changed my mind on the direction flow since I went with the Bay res. Picture attached. Look good? Any reasons why it should be different?
Also I would like input on the best place to place to place the flow meter. At the beginning or my choice the end of the loop?
Thanks in advance...
Put flow meter between "last" block & Res.
If you put it between pump & "first" block, you know you'll have (max) flow, so thats a bit useless
If you would put it between Res & pump (if separate pump & res), it would only indicate how much suction your pump can bring - the Res is a bit of a "dead tide" thing.
Thus the only sensible place is between "last" block & Res... then you'll know what remains of the flow after it has gone through all blocks/rads.
