Fan and bong help
FIRESTARR357
I made a bong cooler and it works great so far I just wanted to know if i replace my 80mm sunon fan with a 120mm would it make it run cooler or is it a waste of time.Bye the way it's a bucket bong THX
Silver
Senior Citizen (aka old fart)
Dallas, Georgia
PigGuy said:
I wouldnt do it, you will just lose more water...
On the money. You will have sprites and use a fair amount of water. Yes, I have gotten a couple degrees c from doing this but the water loss and constant filling took me back to a regular case type fan.
FIRESTARR357
FIRESTARR357
Well with the 80mm sunon fan and my bucket bong i overclocked my 1800+ and these are my temps what do you guy's think? thx for the input
Diggrr
Underwater Senior Member
That's not bad temps there. I'd only switch to a 120mm fan if your going to run it at 7volts to get some quiet. I did this to my bucket too...it was only a 2 gallon bucket, and you could see the water leaving it when the fan was at full voltage....like rain upside down :D
