- Jun 10, 2003
- Eldersburg (Sykesville,) Maryland
I pretty much have it narrowed down to a few choices. I want good performance (looking for better temps than my current Zalman Al/Cu heatsink) but I don't want a screamer or tornado in my case. Given the choices I've written below, I think I can put up with up to 35dba, but not a whole lot more preferably (although I did use to run two 49dba fans in my case, but I did get sick of them after about a year.)
Sanyo Denki 92x32mm- http://sidewindercomputers.com/sanyodenki92mm.html Pretty good cfm vs. noise, and I'm figuring that the extra thickness would provide a good amount of air pressure on the heatsink.
Panaflo 92x25mm High Speed- http://sidewindercomputers.com/pa92hisp.html Pretty much the same stats as the above fan, but with the Panaflo name that everyone loves The hard part would be finding this fan in stock somewhere.
Thermaltake 92mm Smartfan II- http://sidewindercomputers.com/th92blledsmf.html Seems to be a popular choice around here, and I like the ability to change the speed. I definitely would not be running it at max rpm, that's too noisy, so hopefully a medium-ish speed would give good results. Blue LED's are pretty
Enermax 92mm Clear Speed Dial- http://sidewindercomputers.com/92clearulwit1.html Same nice speed changing ability as the TT fan, with (apparently) less noise- and a lower max cfm. I read in a post somewhere that this fan can have a whine to it, but the max dba is definitely lower than the TT with ~10cfm loss.
