Fan Dimensions
Gromet
Does anyone have the dimensions for the holes you would have to cut into a case for an 80mm and 120mm fan? Not just the big center hole, but the for holding screw hole dimensions and locations? Please, I'm working on some designs this weekend, and have no system, or fans to check out.
Thanks everyone for the help...
Gromet
Gromet
OK, that takes care of the 120mm, how bout 80mm?
Anyone?
Koooler King
North America
Virtually all fans are dimensioned in Metric and almost all share the same fan cutout hole and mounting hole pattern for a given size. If you do a Gooogle search on Papst, Sanyo-Denki, or Delta, etc., you will find links to their product specs. and dimensions that can be used as a reliable template for fan size. Good luck.
Koooler King
