Fan Headers On An Asus A7V133
Dutch
Minnesota
I have asked this before....but....., what are the fan headers rated at for wattage, will this mobo handle a couple of Delta High Output 80mm fans with molex connector?, or do I need to get the 4 pin version....
Squid
In my manual it says that you can only use fans up to 350mA on the A7V133, I have 4 fans running off my motherboard.
GW FOP38 (is over 350 so i will change to 4 pin)
1 x 80mm (under)
1 x 90mm (under)
1 x 40mm running on F-Fan which does not support RPM sensing
