So I'm in a tough spot here as i'm running an old Sandy bridge system with a 2600K and an Acer board. This board only has a 4 pin CPU header and 3 pin SYS_FAN header. I tested using Speedfan and it's able to control only the CPU fan so that's where i'm thinking to connect the fan hub to since it couldn't read SYS Fan.
I was thinking to connect the fan hub to the CPU header and control it through Speedfan, since I have an non UEFI bios.
Any recommendations on fan hubs that can do this? I saw that some hubs don't mention the use of CPU headers.
I'm running 2x 3 pin fans (1200RPM) and 3x 4 pin fans (up to 3000RPM.)
